DME Redline Question
On non turbo 944s, what is the method of limiting rpms from climbing?
Is it injector cut out or spark cut out?
Thank you,
N
-Second Q:
What is the system fuel psi (in rail)?
Thank you,
N
-Second Q:
Factory used fuel cut like most OEM limiters. Fuel pressure is whatever your Fuel pressure regulator is set to. The factory part is 2.5 BAR, which is ~37 psi at idle, at sea level. This is the same rev limiter and fuel pressure as a 951.
