Where does this go?
Old 11-23-2016, 03:02 PM
CVR_Rally
CVR_Rally's Avatar
Default Where does this go?
I don't have a picture of where this was on the engine when I took it apart.
Old 11-23-2016, 03:47 PM
V2Rocket
Rainman
V2Rocket's Avatar
**nevermind** wrong one
Old 11-24-2016, 01:27 AM
FRporscheman
FRporscheman's Avatar
I don't recognize that part. Is it from your '84, or your '87 S?
Old 11-24-2016, 07:17 AM
CVR_Rally
CVR_Rally's Avatar
It is from the 83.
Old 11-24-2016, 08:26 AM
Strike-Force
Strike-Force's Avatar
Could it be a heat shield from a catalytic converter?
Old 11-24-2016, 10:05 AM
924srr27l
924srr27l's Avatar
Originally Posted by CVR_Rally
Attachment 1110934
It looks similar to the Steering coloumn joint shield ?
There's some plates that bolt to the head, but it's not them...
Dunno? looks so familar!
R
Old 11-24-2016, 10:09 AM
924srr27l
924srr27l's Avatar
Is it this ?
https://rennlist.com/forums/924-931-...ld-rattle.html
R
Old 11-25-2016, 04:21 AM
FRporscheman
It doesn't look like that part to me. And the steering heat shield is shaped like a half-cylinder, so I don't think it's that either.
Can you post more pictures of it (different angles)?
Old 11-25-2016, 11:19 AM
marc abrams
marc abrams's Avatar
I don't recall seeing a shield like that anywhere on my 83
Old 11-25-2016, 05:13 PM
J1NX3D
J1NX3D's Avatar
the gentlemen of Flussig say it is engine mount heat shield 944 101 033 00
Old 11-26-2016, 03:24 PM
FRporscheman
Hold on, is that thing straight, or does it have a 90-degree bend in the middle?
That angle threw me off, it does look like the motor mount heat shield (a little different than mine, though).
Old 11-26-2016, 03:40 PM
FRporscheman
Old 11-26-2016, 11:41 PM
CVR_Rally
CVR_Rally's Avatar
That's the part! Mine doesn't have the extra cutout though and I cannot locate anywhere it should go. Maybe it is supposed to be on the S and it got mixed up.
Thanks guys.
Old 11-27-2016, 04:54 AM
FRporscheman
It bolts onto the crossmember, under the exhaust manifold. You must have an early '83, because I've never seen this part without the cutout.
Old 11-27-2016, 09:00 AM
Gregs04.5
Gregs04.5's Avatar
Now I've found another part I'm missing on my 84. (I assume the 84 has one as well)
There is a whole box full of stuff missing that got lost when the PO tried to do a clutch job and gave up.
Quick Reply: Where does this go?
