85.5 N/A 944 engine dead. What now?
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
Hey there,
My 944's bottom end is siezed up, and before it did the car started to burn oil. I'm beginning to think that this engine was mistreated by the previous owner and I am looking into buying a rebuilt motor. Anyone have any thoughts on any of the companies selling complete engines out there (i.e. Huntley, Anderson, etc.)? Is there a better route to take on this?
P.S. - I wouldn't mind a increase in the h.p. while I'm at it
Thanks for your help during this rough time I'm going through.
Nerd Herder
I hate to say this but....
Search "Anderson" and "Huntley" and look at the threads- it should make up your mind. IMHO any job worth having done is worth doing yourself.
Best of luck, and Welcome to Rennlist !
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
I was recently in a similar situation and have the following thoughts for you:
* easiest/cheapest/fastest way for more power is buy another car.
* engine swaps in general -- while a fun project -- is alot of work/money (but great if you're looking for something of sleeper car or a Q-car, especially if you're emotionally attached to your car). Remember that you may need more than just the motor. Do a search on "engine swap" and you'll get lots of info.
* if I had to go through the experience again, and if I had a garage in a house, I would consider pulling the engine, rebuilding it and dropping it (or a replacement) back in. 944na motors are fairly inexpensive and you'll get alot of satisfaction if the job goes well -- unless you want a bigger challenge. Plus, if it doesn't go well, you're not much worse off.
Just my 2cents.
Just my 2cents.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
I just did a report of my swap: 968 engine swap. You'll find alot more info by searching old threads.
If you are not greedy for power, a 1988 2.5L from a 944 or 924S would give you a nice little boost (143 HP --> 158 HP,) while a 1989 2.7 L would give you power (163 HP) plus torque. Our cars have very solid bottom ends, so an engine swap would make more sense than a rebuild to me. Maybe refresh the head with a shave for compression and multi-angle valve grind, new rod bearings and seals, but not a big investment in cash. Make sure you get the DME with the engine.
Nerd Herder
Ok Don..
AAHHH!!!! PLEASE dont pirate a 924S.. they are becoming harder to find..
(rant mode off)
There are a LOT of 944's out there- I looked at 2 - ran great but lousy interior/ exterior- could be had for about 1500 around here...
I've never been to newfoundland...
(rant mode off)
Thanks for all the input, I can see how this place can become addictive!
For any of you who have never been to Newfoundland, its a 944 driver's wet dream, winding roads through the hills. check out this link
www.targanewfoundland.com
Nerd Herder
I caught the Targa Newfoundland on OLN earlier this year. Beautiful country to drive- and closed roads unlike europe..
