Belt tensioner wrench(s) & Bal. Shaft tool ?'s Help wanted!
Old 10-25-2003, 07:24 AM
Charlie944
Charlie944's Avatar
Question Belt tensioner wrench(s) & Bal. Shaft tool ?'s Help wanted!
I am gearing up to change the belts on my 84' and on a recently
aquired 86' 951 engined 83' Callaway 944(I'll post pics soon). My questions are these: what do you all use for the belt tensioner eccentrics to move them to either tighten or loosen belt? I was looking at the Baum tool #: 9244 (24mm wrench) or a Snap-on slimline 21/24mm combo open wrench. The Baum looks be non-linear in shaft design whereas the Snap-on is but with a 15deg head tilt. Also do I need the Baum tool#: 9244A (27mm) for the 86' or is it 24mm as well? Furthermore, can I get by with just a plain jane 24mm or 15/16" wrench or 27mm-1 1/16" if needed?
Also in regards to the Balance Shaft Spanner #9200 wrench is it neccessary? Can I use an adjustable or fixed spanner wrench (crescent shaped with a tooth hanging down from the top) that fits around the gear to hold the shaft while loosening and tightening the retaining bolt? I will not kid myself, if I need to buy these tools I most certainly will, but I wanted to get some feedback from all you belt changing gurus out there first seeings how most of you are very ingenuitive.
A BIG TIA to all of you!!
Take Care ~ Charles
Old 10-25-2003, 08:45 AM
944Targa-fan
944Targa-fan's Avatar
I used a BACO adjustible wrench to turn the eccentric rollers and used a self made tool to hold the balance shaft belts.
In my opinion you don't really need special tools to do the belts. Although access is bad, removing the radiator fan gives you some more space to work in.
Good luck
Old 10-25-2003, 10:31 AM
billybones
billybones's Avatar
I have a self made spanner also. It has a pivot point at the back end.. Other words adjustable. I placed an O-ring around it to hold the halves in place so I could let go and not have it fall out of the pin holes. I slightly tighten the lock bolt on the eccentric so it still turns and does not slip then use a snap on adjustable wrench to move the eccentric to where i want it. and then use a deep well socket to tighten the lock bolt while holding the eccentric.. This gets me by the thicker adjustable. The idea of snugging the eccentric first is that it is less likely to move on the final tighten.. I think the most important thing is spend the money on a good torque wrench that will fit your deep well socket.. sizes? I can not remember exactly but all were deep well 6 point sockets. Good luck it is not all that hard just go slow. Get a flywheel lock..
Old 10-25-2003, 10:46 AM
MichelleJD
Jane Bond 007
MichelleJD's Avatar
I also have a self made spanner. I also live about an hour south of you in Ottawa. You're welcome to use it. To make things easier, I'm on my way to spend the weekend in Galena and could meet you somewhere. PM me if you're interested. I'll check the list b4 I leave (11am to noonish).
Old 10-25-2003, 10:53 AM
Geo
Geo's Avatar
I haven't used them yet, but I bought these. The quality is not as high as the commercially available pieces, but these look like they will certainly work well enough and for a lot less money.
http://www.arnnworx.com/Personal%20Web%20Page.htm
Old 10-25-2003, 12:47 PM
MichelleJD
Jane Bond 007
MichelleJD's Avatar
Charles:
You have a PM.
Old 10-25-2003, 12:51 PM
Conor
Conor's Avatar
I used a large pair of 90 degree needle nosed pliers for a spanner. Worked out fine.
Conor
Old 10-25-2003, 07:51 PM
Charlie944
Charlie944's Avatar
Hey thank you everyone! Sorry Michelle I was unable to check the list here before now (I was at work). A special thank you to you Michelle, I would have certainly taken you up on it. Geo, I looked through that site and I may go with some of the tools there. I did buy a flywheel lock from 944Racing when I got the rest of my parts. I will keep you all posted.
Thank you again!
~ Charles
Old 10-25-2003, 09:17 PM
Red 944
Red 944's Avatar
I just got a couple spanner wrenches from the Mac guy for my coilvers, they weren't cheap .. $70 a piece, but they're nice, industrial finish, heavy metal pieces. If you want to borrow one just lemme know
Old 10-25-2003, 10:22 PM
Charlie944
Charlie944's Avatar
H
Old 10-25-2003, 10:27 PM
Chris_924s
Nerd Herder
Chris_924s's Avatar
Hey Charlie- next time I'm gonna be in Rockford (Halloween?) I'll drop you a PM.
Michelle's spanner would have definetly done the trick. good torque- big long handle.
Charlie944
Charlie944's Avatar
Hey Red, thank you for the generous offer! I am going to make an adjustable pair myself. Again thank you everyone for all the info and offers.
I appreciate it all!
Take Care! ~ Charles
Old 10-25-2003, 11:00 PM
Charlie944
Charlie944's Avatar
Does anyone know, or be willing to tell me what the pin size is for the balance shaft spanner tool? I would greatly appreciate it!
TIA!
Old 10-26-2003, 05:25 AM
Charlie944
Charlie944's Avatar
Hey Chris that would be cool! Yeah I wish I could have caught her in time. Oh well, I am going to make one here Monday with a 10 inch handle, or longer...I have a 4ft piece of 0.5" square stock to work with. Hopefully by Haloween I will have my car back together along with the Callaway.
I'll look forward to hearing from yah Chris...take care man!
~ Charles
P.S. Anyone have the correct pin diameter for the spanner?
Old 10-26-2003, 07:34 PM
MichelleJD
Jane Bond 007
MichelleJD's Avatar
I'm going to have to return to Mt. Carroll next weekend (bought an antique rocker that wouldn't fit in the back of the Porsche), so if you can wait I'll be happy to bring it to you.
Don't know the pin diameter size, someone made the tool for me - sorry
Quick Reply: Belt tensioner wrench(s) & Bal. Shaft tool ?'s Help wanted!
