Radiator - What's recommended?
Well, since it did not fit. I mean, at least the hose connectors are (mostly) the same. :/
You can put it in with zip ties in a lot less time but if you do it right and make a new bracket, etc.
Well, hourly rates are lower here, but still amounts to ~450 euros. Like I said, go with OE radiators. Or shove this in somehow that works for you.
I had a fitment issue with the thermo switch. If you notice on the OEM radiator, the mounting bung is slightly offset. Not so with the aftermarket unit. Had to modify the fan shroud to get it to fit. Also, swapping the speed nuts for the fan shrouds didn't work well.
UK_in_NY (01-11-2020)
944online.com but you can find them from ebay sellers also. But they have seemed to go up in price since I bought earlier this year. 944online has them for ~$360.
Pelican had Modine (L&R) for $299
http://www.pelicanparts.com/More_Inf...RoC-OcQAvD_BwE
bump...curious on OP/924 2,7 R/anybody else's experiences with the ebay radiators...
looking at turbo-size units specifically, cheapest OE i've found is $400, worley is $200 shipped.
OE is expensive, but it did last a LONG time. If you buy another it'll likely be the last one you ever buy for the car. Not likely with an aftermarket unit.
