Clicking noise in steering wheel??
Strange--I posted this, and it vanished!?
I am getting a strange (and annoying) clicking noise in the steering wheel/column area when I drive. It's not a mechanical problem--sounds more like plastic vibrating somewhere inside the steering wheel assembly. When I drive and put downward pressure on the wheel, the noise decreases.
Any ideas?? Can I take the wheel off, without the airbag going poof?? It must be something loose in there causing the clicking/rubbing sound. It's not a major problem, but since I removed the rear cargo cover and solved that rattle, I am on a quest to have a quiet sounding interior!
Thanks.
Thanks.
there is a technical service nbulletin about this
its to do with the console rubbing against the wheel column or something,
1> try a small suirt of wd40/silicone lubricant
2> ask someone for the porsche tech bulletin/ your porsche dealer as well.
I cant find mine at the mo
Ree-hee-lyy!? Interesting. I'm not alone!
Any idea WHERE I should be shooting WD40 in there? I would hate to melt the console! There is a rubber boot at the back of the steering wheel. Could it be in there somewhere?
How can I get a copy of the service bullitin? My Porsche dealer never heard of the 944!
I have the clicking sound as well....sounds like something plastic. ( 1985.5 944 )
Not wild about squirting anything under there....the sound is definately something 'clicking' as opposed to something rubbing so I doubt any lubricnt would make a difference or solve the problem longterm.
Wow, old post!!
Funny, I was just noticing how my clicking/rubbing sound went away at some point--gone now. Not sure why. But my sound was definately plastic rubbing on plastic. Made a clicking noise because it would rub as the steering column moved resulting from bumps in the road.
Try holding your hand around the rubber steering column hub...see if the clicking stops.
Sounds like maybe temperature related. Expansion ,contraction. Did you have the heat or defroster on? That might help find the area better. Are you turning the wheel when it happens? That's how I would try to locate it. Check any trim screws for looseness. I've been under my dash now for a couple days and found quite a few. I've also started having pizza delivered while I'm under there!
Originally Posted by vette4lyfe
There is a metal place behind the steering wheel.. its probebly bent a lil outward.. get a screwdriver and push it back in... that fixed mine..
