944 transmission oil
#46
ok, so i open the fill plug THEN open the drain plug and drain the oil. THEN i pop the drain plug back in and fill the oil and pop the fill plug in................................................right?
#51
Just kidding ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Actually, there is some truth to the transaxle fluid "filter"...
You should always strain the fluid you remove from the transaxle to check for "particulate". You can sometimes avoid component failure by examining what the fluid carries out... or, at least know that the end is near. Coffee filters work okay, but they're really too dense. I use old white t-shirts. Just run the fluid over the material before it enters your catch can. This is good practice for any fluid coming out of the car... engine oil, coolant, ps fluid, blinker fluid, etc.
Good Luck!
Good Luck!
#52
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Skip is just messin' with you, there is no filter.
For your reassurance I put MT-90 in around 103k and I have
almost 170k on that same oil, never any leaks either.
I will probably change it here before winter though.
Take care, and it is dreadfully easy, oh while you are back there
you might want to change your fuel filter...remember when it
was done last?
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
#55
