The most seized clutch fork pin ever
FROZEN CLUTCH FOR PIN
It seems I may have had worse than anyone so far but, good news, I concocted the most fool proof method yet. I tried slamming a slide hammer for an hour, torching the bell housing, slide hammering some more, using a bolt to clamp against a deep well socket to draw the pin out. With the last technique I was able to pull the pin out a quarter inch before it stripped the first 4 threads straight out of the pin.
What worked for me was to remove the bell housing with the PP still attached. There is a hole in the bell housing which you can easily access the back of the pin and bash it out with a hammer and punch.
You can remove the PP by removing the 6mm Allen head bolts that hold the PP to the flywheel. Reach through the hole in the bellhousing where the starter sits to access the bolts. I had somebody lay in front of the car and rotate the crank as I removed the bolts. It took me about 15 minutes to undo the bolts, drop the bell housing and bash the pin out.
This was surprisingly easy and I was able to do the hard work on my bench. Next time if the slide hammer doesn't work I'm going straight to this method. It certainly beats laying on your back getting ****ed by a hard rod for 2 hours.
Fork Pin removal - back driving it
When the pivot pin is removed, locate the stop pin (that fell into the bell housing) and press it back in. Stop pin pointed out below.
K
My next door neighbor came to me exasperated by a stuck clutch fork pin.
I made him this as an emergency measure and he has used it successfully now on the original problem clutch and another one.
IIRC its a length of 12mm all thread with a short length at the end turned and threaded 8mm for the pin.
The piece of 3/4 hex rod is tapped 12mm and is used as the jackout nut.
Cheers,
Wilson Logan.
Cheers,
Wilson Logan.
Cheers,
Wilson Logan.
Cheers,
Wilson Logan.
