The most seized clutch fork pin ever
what tricks have worked for you guys in getting a stuck pin out? I'm trying to free the pressure plate from the bell housing and I have it on my bench. I've tried everything. I've soaked it in PB blaster, I've heated the pin with a propane torch, I've tried a bigass slide hammer. I tried beating the pin out from the top where it's visible opposite where you thread the puller bolt in, I've tried drawing it out with a big socket and washer against the bellhousing, I've tried using a prybar and a 3 lb hammer against said washer/big socket setup. The thing hasn't even budged. Looking into the bellhousing it's obvious the pin is seized badly to the bearings and I don't care about destroying the pin, the fork, or even the bellhousing at this point. I just want the pressure plate and throwout bearing intact. I'm about to perform surgery on the bellhousing with my cutoff wheel. Does anyone have any sage advice I havn't tried yet before I sacrifice this thing to the Porsche gods?
God I ****ing hate this NA. I feel like I'm losing my mind fighting this thing at every step to bring it back to life.
I had one like that on my 968. I took a flat steel bar (about 3/8 " thick) and drilled a hole in the middle of it. Braced the bar on the ends so that is was about one inch under the pin. Put the bolt through the bar and into the pin and start turning and it pulled the pin out.
I wish I had a picture, started to make one when I did it.
My best bet was making something like this, but even that didn't work. I had to stop because the bolt started to neck down and I was afraid of snapping it off in the fork pin.
http://www.arnnworx.com/catalog/inde...8#.V3RwiNWEDIU
It looks something like this. This might be the one I used. The steel bar would fit to where the center was about an inch or more below the pin. I don't think I had to use any kind of shim on the ends to keep it away from the pin. I may have had to use a longer bolt. Turn slowly and do some tapping on the bolt and it will pull the pin out. I'm not very good at explaining.
Put a washer next to the bolt head.
Doug, I marked my bolt so that I would know when I was all the way into the pin and no more thread. Don't run out of thread and break the bolt off in the pin. Seems as if I used 2 or 3 different length bolts but it made the job real easy. I had worked for and hour and had never got it to move.
I'm disgusted, I dont want to look at it anymore tonight. I stripped the threads off 4 bolts attempting to "jack" it out, I don't know what alloy steel the pin is made of but its hard as hell. Even my air hammer with 120 psi behind it only managed to scar the hell out of the opposite end of the pin but didn't budge it. Tomorrow I'm going to take a cutoff wheel to it, there is simply no way its coming out. It's welded to the fork bearings. I have a spare fork, pin, and bell housing.
The 968 may bell housing may be a little different. This is a picture of the bar and the bolt going into the pin . Threaded rod would be better screwing it into the pin and then turning the nut against the bar to pull the pin. This is not a good picture but will give you the idea. I can't look at my 944 so the bellhousing might be different In the picture the bolt is too large and would not go into the pin, if you look closely it is not straight. Threaded rod would be the way to go and screw it all the way into the pin then it would not strip. The nut against the bar might strip but I would give it a try.
Van, I've done over a dozen clutch jobs on 944's, never had one that took more than 5 minutes to remove either. This one has resisted all but complete nuclear annihilation. I can't wait to get it out and post pictures.
Victory is mine. I ended up using a deep 16mm thin wall socket with a long grade 12.9 bolt and some washers and cranking on it with a 24" breaker bar figuring if the bolt broke, out would come the grinder. To my surprise, it slid out. Even more shockingly; after cleaning all the grease and liquified rust off the shaft it appears totally fine...reusable in my opinion. Doesnt even have marks on it from the roller bearings like most of the pins I've taken out. The bearings were totally shot though, the rollers practically fell out of the races once the pin slid out. Thanks for the encouragement and letting me vent gentleman!
