Hard to start thread
Old 05-06-2016, 12:17 AM
No Lag
No Lag's Avatar
Default Hard to start thread
It seems there are many issues with hard to start so I thought it a good idea to see if we can get a basic list of how these issues were solved. Perhaps list symptom and how you solve it?
My problem seems like it's fuel related. After a hard to start episode I get white smoke then idles and runs perfect. Shut it down and it starts right up no problem. Warm up the engine, wait 15 minutes then back to the same issue.
The list of parts I have replaced so far without solving the issue: Fuel regulator, coolant temp sensor, fuel filter and check valve.
Ideas please.
Old 05-06-2016, 12:19 AM
No Lag
No Lag's Avatar
Forgot to mention it's a 91 S2 with 64K.
Old 05-06-2016, 09:41 AM
ramius665
ramius665's Avatar
No sense in making a thread for hard starting, just ask for help and people will offer ideas.
Have you looked at the Garage Shop Manual on Clarks-Garage.com?
Old 05-06-2016, 10:14 AM
V2Rocket
Rainman
V2Rocket's Avatar
Please describe in detail the hard to start situation.
Be specific about what happens, how long it takes, noises, etc.
Ideas please.
Old 05-06-2016, 07:36 PM
mytrplseven
mytrplseven's Avatar
Did you do a fuel pressure and leak down test? I'd also recommend doing a vacuum system leak check. There's several posts here on easy way to do them. Also keep in mind that there's vacuum leak possibilities under the j boot and the intake manifold.
Old 05-07-2016, 01:30 PM
No Lag
No Lag's Avatar
I pulled the vacuum line off my fuel pressure damper and fuel is dripping out. Not good right. There should not be fuel on the vacuum side I'm guessing. I'm thinking the diarpham is bad allowing fuel to pass. Make sense?
With the vacuum line taken off I caught a pic with fuel starting to drip.
Old 05-07-2016, 03:36 PM
No Lag
No Lag's Avatar
Cut open the fuel filter for fun. Here's what a filter looks like with 64K on it!
Old 05-07-2016, 10:54 PM
mel_t_vin
mel_t_vin's Avatar
Correct...not good.
Old 05-08-2016, 08:08 AM
Jfrahm
Jfrahm's Avatar
White smoke is usually water, I'd check the plugs right away. Post a pic. Coolant in a cylinder will make it hard to start until cleared.
Old 05-08-2016, 08:33 AM
944crazy
944crazy's Avatar
Yeah, could be a leaking head gasket if there's white smoke. If it's coolant in the cylinder, it will start and only run on 3 cylinders for a little bit and sound very different to normal. You can see which cylinder it is by feeling which exhaust header is cold. Then check that plug. This is what happened on mine, and sure enough it was a leaking head gasket.
Old 05-08-2016, 01:48 PM
No Lag
No Lag's Avatar
Good advise guys. Thanks! I'll be doing some checking,
Old 05-09-2016, 12:02 AM
No Lag
No Lag's Avatar
Looks like the fuel damper was the trouble. New one on order. I plug the vacuum line from the damper and the car started perfect. First good cold start since I have own it!
Thanks everyone for the advise.
Quick Reply: Hard to start thread
