A simple suspension question (like there is such a thing, right?)
So...I've got this 968 Turbo Project that is finally looking like it is going to finish up. As the cars suspension components are bone stock, I've figured out I want to do something about while I still can.
To that - I've upgraded the sway bar assemblies to the 968 M030 sized components and sourced a pair of the front springs from the 968 Club Sport. Figured I'd stick in a set of Koni Sport Struts to finish off the front. For the rears - thought I'd go with the Koni Sport Rears, but then I got a hold of a set of M030 springs and the associated washer. To complete the rear I'm faced with the dilemma of either sourcing rear M030 shocks - or a suitable replacement if I want to use the helper springs.
So...the question is there a suitable replacement shock that can be used with the M030 Spring/washer assembly?
Kind of related is the impact on the ride height. Seems like I may have to re-index the torsion bars to compensate for the extra spring height...anyone experience this?
TIA-
TIA-
Rainman
Don't know if you need adjustable, but I have a pair of non-adjustable Koni rear shocks from a 1983 that you could have for free + shipping.
I think the lengths are about the same early vs late 944/968. You would need to:
1) drill the lower metal bushing to 14mm and check "offset" of the shock eye
2) cut a snap-ring groove into the shock body to support your coilover spring
3) send them to a Koni shop to be rebuilt. Koni can cut the ring groove.
