Engine Build Thoughts
Set the redline a few hundred rpm past max power for whatever cams you've got.
No point going to 7200 if your cams peak at 6000 or wherever.
Lightweight lifters are available from 928 motorsports...
Run a good (thick) oil. 50 or 60 weight, to keep oil pressure up at high RPM...
...or...add displacement
If you will keep the engine NA forever, I bet you could find some clean 944S2/968 pistons and bore your block to fit.
Doesn't cost any more to bore to 104 than it does to 101mm. The cylinder walls will still be thick enough. You would need longer rods if using the 2.5 crank though.
Adding displacement has the effect of moving down the power range of cams...more cubes = less revs required to flow a certain amount of air, to make target horsepower...
Why would longer rods be necessary if I'm only changing the bore, though? I'm not really interested in increasing stroke (to keep the high-revving nature of the motor intact).
That's my thinking, too. I've wondered if it would be possible (or even advisable) to run smaller clearances in the engine to allow the use of thinner oil and help protect against cavitation and air entrainment.
Is there any reason a 944 engine can't be built with tighter bearing clearances? I've seen engine build literature that suggests that it's no real issue to do this, it's just a matter of proper fitting and precise machining. But I figure that with rod bearing failures being a somewhat common issue and the fact that these cars have been around longer than I've been alive, someone has probably already at least considered this possibility, if not actually done it before.
Are there other aspects in the engine besides just bearing clearances that affect what oil viscosity is appropriate? What I've read so far deals only with bearing clearances, but I know that's not the only place oil flows in an engine.
A big thing is the temperature that the oil is at, here are a couple Mobil 1 oils plotted across 0 to 100* C.
I'm not sure if our engine oil gets hotter than average cars, but I do know many other German cars (especially from that era) also run thick oil.
944 on race track runs about 205F oil temp, close to 100C. Graph shows very low viscosity at that temperature, good reason not to run over 6500 rpm, and only seconds at 7000 rpm
because if you used S2/968 pistons on a 2.5 crank with stock rods, the pistons will be 4.5mm below deck.
Couple of thoughts.
The Firestone Firehawk series 944 S2s had their rev limiter set at 7200 using a stock bottom end and valve train. The 16V motors can take 7200. The 944S exhaust cam is hotter than the S2 cam and the intake cams are the same. It's very noticeable on the 944S when it comes on the cams compared to the S2.
A good friend's 944 S2 made 199hp at the wheels with the following modifications: 968 intake manifold, cat delete, 951 cat-back and MSD ignition coil. He has since added a SciVision MAF which made a significant difference on the butt dyno but hasn't had it dyno'd yet.
My 944S has the same modifications minus the cat-back and is considerably quicker than it was with the AFM and 944S intake manifold. Freeing up the intake side appears to make a much larger difference in power output than opening up the exhaust (but it does sound great on WOT!).
If you're interested in building a new motor that will rev freely and really be a kick in the pants, I completely agree that you should lighten the rotating assembly by replacing the con rods and flywheel but you might not get much out of cutting down the crank. Also, you can safely go up to about 11.9:1 compression with new pistons and it should really make a difference. Lightweight lifters are available from a few sources at around $16/ea but realistically you'll only spend a few seconds at/around 7k so you might be better served spending your money elsewhere.
Couple of thoughts.
The crank machining is for reduced weight but mainly for reduced windage via knife-edging to help control oiling issues. It may be overkill on a car that will probably never see more than 25% track use, but it seems like a half-effort to me to lighten the reciprocating parts without also lightening the rotating parts.
I currently have an S2 intake on my S and I think it was worth a boost in throttle response and mid-upper range power, though that's only a butt-dyno reading. I wonder if there is a big difference with the 968 intake?
This should be step 0 in anyone's list of adding performance - ditching the AFM setup, by any means necessary.
You want to make power high enough and shift at a certain point that the next gear ratio will land you in the meat of the powerband so you're not bogging waiting for the cam/turbo...
I've been rolling this over in my head and it makes sense to me that a thinner oil will resist cavitation and air entrainment better than a thicker oil. The research I've done in the last few days agrees with me.
Another thing to consider is the areas of the engine that rely on splash lubrication, such as the cam lobes against the lifters.
