Need a Radiator
Need a Radiator
Title says it all. Looking for a radiator for my '89 2.7 944, standard transmission.
Would like to find a good used one, if anyone happens to have one laying around. (Not really hopeful, as I went through 3 used ones while trying to replace the one in my 951. Eventually bit the bullet and went new, but you never know...)
LMK.
Thanks.
LMK.
Thanks.
I replaced my brothers radiator with my turbo back up unit and had to steal the support from my 951. Bought two more 951 lower radiator supports from Lart. I just ordered the 56mm aluminum unit from China. Yea I know. But I've look up one rennlist post already and it worked out after 6 hours of installed time and some radiator fan assy modifications because the radiator is so thick. Then my current turbo radiator is going in my 86 944 to replace its leaking radiator.
If you get a turbo radiator make sure you get a 951 lower radiator support because it's differant then the 944N/A's and a fan shroud because the whole turbo radiator setup is taller.
Sneaking in here to say I also need a new Rad, whats the word on quality, is it worth 2x price increase to take the Porsche part vs an OE supplier part? I can find replacements ranging from 400 to 800 shipped to me.
Before I got another plastic tank radiator I would look at all the 100% aluminum units first. The only failures I have seen on all the Porsche 944/951 radiators have been the plastic end tank seal to aluminum body leaking.
