Nitride Harden Crankshaft?
Hello,
I need to have my crankshaft machined and am curious if it's thought that it should be re-hardened? The shop doing the work said that Porsche's crankshafts didn't require it because their hardening is fairly deep compared to other makes. Any opinions on this out there?
Thanks!
Rick
Thanks!
Rick
Team Owner
From: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
cranks ain't the problem.
it's the uber snarky German engineering, petulant engine, lousy oiling, no starts, running hot and sharded belts that KILL you.
I'm sure that if you want to do more to the crank after machining, you can.I'm sure that your machine shop has access to cryo stress relieving vendors. After that, if you wish you could get it re-hardened by getting it to a re-nitriding vendor..just costs $$...You might also want to check with a local gun shop..They use these procedures too.
Hello,
Thanks!
Rick
Thanks!
Rick
I hope I'm confusing the description of hardening process they're using, because I wouldn't call it cheap. To get the crank turned will be $250.00, and the hardening process is $500.00. I've already got ~$600.00 for cross drilling the #2&3 rod journals.
I think you need to find a different shop- the expensive,pro shop I use charges less than half that for grinding and nitriding.
I didn't have my crankshaft nitride treated after I had the rod bearings turned and cross drilled. Porsche 944 crankshafts are just about the hardest crankshaft in the world. If you offset ground the rod journals for a longer stricken using Mitsubishi eagle rods like some have some then I would recommend the nitride process.
I can't believe this guy. Totally forgot about the fuel lines cracking and catching the car on fire. If your going to hate at least get the top killers in there.
Right now I'm thinking I'll err on the conservative side and have it done.
I was going to run the crank as it is, but then the loose clearances began to bother me...AFTER I spent all that money on getting it cross drilled. In the end it'll just keep pushing back the date of completion, which has no deadline anyway. It could be in 2016, or 2017...
