Fluid filled Motor Mounts?
Are they still available? I heard that they are not.
The reason I ask is I recently changed mine, with a new set that I've had for a sitting around couple of years, and I really didn't notice any difference, so I'm thinking the ones I have are not fluid filled.
Randy
Randy
I was under the impression that all the mounts had "fluid" in them.
When I asked the dealer he said that he wasn't sure if they are or not. The dealer's were about $100 each and I paid $100 for both, so I'm thinking I didn't get the fluid filled ones. But then again if the Dealer has the same ones (non- fluid filled) then I got a heck of a deal.
Randy
Randy, is it just me or have you noticed that a lot of the cars on this board have the same problem at the same time? I mean Tabo, you, me, and somebody else were all doing clutches at the same time, no we're all looking at the motor mounts, various intermitant stalling problems etc.
Yep, misery loves company.
Yeah I'm real intrested in TaboII's clutch diagnosis. If he has the same lame *** clutch plate as I do, then I think Vertex might be pulling a fast one. I'm convinced the one I have is not a Sachs unit at all. I think he's taking it apart this weekend with his friend the "mystery mechanic" LOL.
The mounts I put in aren't collapsed or "bad" but they also don't feel any different then the ones I took out. A little bit of a rough idle that I can feel in the steering wheel, which I'm told is an indication that they are bad, at least for the fluid type.
I took my car over to a friends today and put it on his lift. I took the exhaust mounts loose and repositioned the whole system, and also repositioned the little flywheel cover, and no more ratlle! Smoooooth as can be now!
Woo Hoo
Woo Hoo
You guys are correct. There are some aftermarket motor mounts that are solid rubber and don't have any fluid in them. Then of course there are the solid metal ones for the track. I hear those will shake your teeth out if you use them on the street for long.
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Randy
I believe that Porsche still sells the fluid filled ones except they only sell the ones that they used for the 951 (you can still use them for N/A's). The aftermarket ones can be either solid rubber or fluid filled. When one buys motor mounts for the street, they should go with the OEM ones for about $100 each and skip the aftermarket fluid filled ones for about $50 each. Although I haven't used any of the aftermarket ones myself, I have heard that they fail prematurely and that motor mount replacement is not a job that you want to do repetitively.
I am going to replace mine with the solid mounts from Lindsey. I have heard that they will add some vibration but with 400-500lb front springs on the street whats a little more vibration :>)
BTW - as far as failure, the hydraulic (liquid filled) mounts will fail first and the all rubber will tear eventually, these are wear items and will have to be replaced every so often, therefore the solid aluminum mount!! I guess their supermount system would be good for a street car but they are 250 a piece! They do however come with a lifetime warranty.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Nerd Herder
Yep- me too on the motor mounts. Been wanting to replace them for almost a year. It's just the general age of the components vs wear and tear. We'll all replace them eventually. The same has been happening on the flex disc (auto flex damper) I did mine last summer, since then I personally know of 6 more people going thru this replacement this summer.. Sheesh.
Randy, so you're having a problem with the clutch plate? What is it doing?
But it's all good now. About 200 miles on the clutch so far, and all is well.
Randy
Just curious about the mounts as it has come up on the 928 board as well. the 928 mounts are fluid filled and fail between 65-90K. We've found that Anchor 2698 mounts replace our Porsche mounts exactly for about 1/4 the price. Being that the engines are similiar (well, at least on one side) - wonder if they might work for you guys too?
Just a thought.....
Just a thought.....
