Most useful non-standard wrenches?
Old 10-20-2015, 01:25 PM
dmjames
dmjames's Avatar
Default Most useful non-standard wrenches?
So I have a good set of your standard, run of the mill combination wrenches (one open end, one box end). I'm in need of at least a handful of new wrenches to use for counter holding in scenarios where I can't get a socket onto either side.
I figure if I'm buying new wrenches, I ought to at least see if there's anything you guys have found particularly useful, so long as they still serve for normal counter-hold purposes.
What non-standard wrenches have you found the most useful? Ratcheting? Flex?
Old 10-20-2015, 01:36 PM
odonnell
odonnell's Avatar
Offset for sure. There have been a lot of times when I wished I had ratcheting wrenches. But even since I bought some last month, I've only been able to use them once Generally because if I can't get my socket on it, there isn't enough room for the ratcheting wrench either. But still nice to have them.
Also have used a service wrench set extensively for large (20mm+) hex. I got Pittsburgh Item# 93668 and the quality is honestly pretty poor. When I use a cheater bar over the handle, for example removing a 24mm nut or O2 sensor, the jaws of the wrench sometimes deform and slip off the faces of the fastener.
Old 10-20-2015, 01:46 PM
dmjames
dmjames's Avatar
Don't know how I forgot about offset...
Hadn't ever actually heard of a service wrench before now, but man, would have killed for a set when I was doing the fuel lines... The late routing through the wheel well would have made the job super easy, but a wrench that would fit into such a small space easily would certainly have helped.
Old 10-20-2015, 02:03 PM
V2Rocket
Rainman
V2Rocket's Avatar
ratcheting wrenches are super useful on a 944 cramped engine bay.
also...something that has WOW'd every person whose car i've worked on...
Blackhawk By Proto GW-9946R Drive Rotator Ratchet, 1/4-Inch - - Amazon.com Blackhawk By Proto GW-9946R Drive Rotator Ratchet, 1/4-Inch - - Amazon.com
they make it in 3/8 as well, the handle twists to do the ratchet action if you cant actually turn the ratchet like normal.
Old 10-20-2015, 02:53 PM
CO951
CO951's Avatar
I got a 3/8 like that at harbor freight a few years ago. (I don't think they sell it anymore.) Has come in real handy a few times.
I've found stubby wrenches to be quite helpful on occasion.
Old 10-20-2015, 03:30 PM
Arominus
Arominus's Avatar
I got a set of Wera Joker ratcheting wrenches from my GF for my birthday this year, they came in handy when i had to pull the head on the engine a month later. Great for the exhaust manifold nuts and various other bolts. Get some ratcheting wrenches for your kit, they are very useful.
Old 10-20-2015, 04:21 PM
Van
Van's Avatar
Gear wrenches are very handy. So are crows foot wrenches. And a few flare nut wrenches for brake lines.
Old 10-20-2015, 04:35 PM
divil
divil's Avatar
I have a set similar to that from Harbor Freight - it's not identical to the pics of that item # on their website (mine are not shiny chrome) but very similar, and they're actually pretty good. They do look cheaply made but I have used them for tons of things on the 944 and put massive amounts on force on them with no issues. If they didn't break when I was removing my oil lines, they never will. They are great imo because it's a very cost effective way to get all the odd/large sizes that you'll only use once in a blue moon. I think my set goes up to 36mm.
But I think what I've felt the need for more often than anything is shorter wrenches. Not having room to turn them is the most common problem I run in to. When I was buying ratcheting wrenches I obsessed over which features to go for - flex head, stubby, reversible...it seems you can only have 2 of these 3, at least with what I've seen out there. You *need* reversibility for ratcheting wrenches, so it often comes down to a choice between flex head and stubby sizes. I went with full length flex head, and I kind of regret it. They are extremely frustrating to use. You basically have to keep one hand on the head all the time, or else it will flex and pop right off. Since you can't really put any force on it when the head is flexed, it's really not that useful - you must be able to fit something else on there to break it loose in the first place. There are flex head versions that are lockable, but usually not reversible.
Old 10-20-2015, 04:41 PM
CO951
CO951's Avatar
Van, I've seen crow's foot wrenches, but never used them. I've never even thought "what I need to make this job easier is a crow's foot", which probably means I'm doing something the hard way. What do you use them for on our cars?
Old 10-20-2015, 04:53 PM
CO951
CO951's Avatar
I got these wrenches a few months ago for a bolt inside the door of my Toyota. I haven't run into anything else I couldn't do without them, but had a few things they made a little easier.
http://www.sears.com/craftsman-7-pc-...&blockType=G42
FYI, looks like they're 50% off right now (which is what I paid for them).
Old 10-20-2015, 08:08 PM
Van
Van's Avatar
I've used them to take the crossover pipe off the turbo... Also used them with my torque wrench to get the girdle nut under the oil pickup tube.
They're just handy to have in your arsenal of tools.
Another one is swivel sockets. I have a 13mm, 17mm and 19mm, which is great for the upper bell housing bolts.
Old 10-20-2015, 08:46 PM
marc abrams
marc abrams's Avatar
One what I can hit with a hammer
Old 10-20-2015, 09:54 PM
fasteddie313
fasteddie313's Avatar
My favorites are my Stahlwille stable 20 series deep offset double box wrenches..
IMO Stahlwille make the best utilitarian metric tools period, they are the tools Audi VW Porsche BMW and most German car maers design there cars to be worked on with. I saw a 911 timing bet change specifically call for one of those stable 20 deeps..
My most life saving wrenches are likely my stubby ratchet wrenches non-reversible no offset along with many cutoffs.
Good assortments of extensions are also very valuable, SK gets m vote for there extensions because I like how beefy they are, beautifully chromed, and excellent knurling.. Universal joints are also must haves.
Quality ratchets are also important to me, I don't have one yet but I'm liking the new Armstrong MAXX 80t ratchets..
My syandard 3/8 snap-on ratchet gets most of my use despite having all sorts of flex ratchets and such I find a standard ratchet the best most often.
Something really important here is the need for quality tools, The danger of sh*t quality tools is not so much that the tool may break, its the fact that sh*t quality tools are many times more likely to round off nuts and destroy fasteners turning simple jobs into huge projects..
Like these cheese head bolts on your cams, I bet much less of you would strip out the heads of those if you were using top grade sockets. No way would I even attempt that with some china crap socket, not even craftsman.
Don't buy tools to work on a Porsche at walmart, check out SK, proto, stahlwille, hazet, snap-on, wright etc. for a truly good investment..
Old 10-20-2015, 10:01 PM
V2Rocket
Rainman
V2Rocket's Avatar
funny you say this, there was talk about this bolt in another thread yesterday...
i've worked on more 944s than i can keep track of, and done/undone this bolt and all the others countless times...with a bit from an $8 set of 4 cheeseheads from autozone. never had one strip or really even round out on me.
cranked on by a 1/2 (or even 3/8) breaker bar from harbor freight.
almost all my sockets are from harbor freight, as well as my allen keys, torx bits, etc...i've never broken a single one.
in fact the only HF tool i've ever broken was a cheap 3/8 ratchet that came in a $4, 40-piece (!) socket set...but what do you expect.
there are situations where certain brands may outshine the others, very high torque situations for example, but for the most part...13mm in stuttgart is still 13mm in taipei.
a tool is a tool, you just have to use it right. that said, tools are like oil brands/weights, everyone has a preference and none are really wrong (unless your wrenches come in 10w30 )
Old 10-20-2015, 10:18 PM
odonnell
odonnell's Avatar
Only HF tool that's physically broken on me was a 3/8" to 1/4" drive adaptor. Most of my hand tools except my socket set (which is Stanley) is HF cause I was a college student until recently and honestly, I only had the expected problems like I referenced earlier in this thread. No regrets.
Well...I bought an electric tire pump there and it broke immediately, but that wasn't a hand tool.
Quick Reply: Most useful non-standard wrenches?
