968 Starter Solenoid
Any one know the part number and/or where I can buy a starter solenoid for my 968? PO buggered up one of the terminals, cross threaded, and one of the cables is loose. I discovered it when doing clutch. Car starts reasonably well but I need to fix a bad connection. I don't really want to buy the whole starter when its an easy solenoid replace,
I recall that the 968 MT6 starter is similar to the 944 starter but with a longer snout for the DMF. The 944 starter I believe is the same as a VW Rabbit/Jetta starter but with the wiring swapped for reverse rotation. If all this is true a VW Bunny solenoid should fit and work. I dimly recall a 944 owner doing such.
And so it was:
http://www.arnnworx.com/catalog/inde...d=25&chapter=1
Take a look at the Bosch 9330081039 ($80) or the Standard SS262, $20 which fits a panoply of VW/Audi from the 80's.
Cheers,
-Joel.
And so it was:
Cheers,
-Joel.
Porsche 944 Starter Solenoid
Amazon has a rebuilt starter for $100-ish.
I bought just the solenoid from ebay. $30 shipped. Might still be available.
http://944time.com/porsche/944starter.php
Not an option... the solenoid also serves to kick the starter gear out to engage the teeth on the flywheel... Ford starters used a totally different method to do that; I think it was just intertia of the gear that would ride up a screw when the motor started spining.
Thanks for your comments.
Looks like the Bosch number on the solenoid is 0331 303 134-634
I can find numbers very close, but not quite the same. Looks identical to this:
http://www.maniacelectricmotors.com/66202026.html
This one works on VW, Porsche 996, Audi, etc.
