Clutch replacement hardware kits
Anyone find this on their clutch replacement project:
The 9 bolts, triple square, that hold the flywheel to the crank in my car are 10x62mm but when you buy a "hardware kit" or OEM bolts with the proper number they are 10x18mm. Not even close.
I have seen a mention of "if you have a replacement flywheel" they require 10x62mm.
Anyone find the same issue? There is a huge difference between a 62mm and an 18mm long bolt.
