PN for dowel pins between block and bellhousing?
My block came without these pins. I can't find the PN in th PET.
I hope someone knows the dimensions and or PN.
I'll check what's in my shop tomorrow. I have ordered them, and hope I still have the part number somewhere. The block side (where they reside) has three raised areas, and the bell housing side is a close slide fit (as all of us know).
I believe I found the correct dowel pin on the 928 parts list, a 12 x 18 mm pin in the correct location on the V8 block, PN 900 012 070 00. I'll check what I have tomorrow.
I can't find any 10x12mm dowel pins from a source which will let me buy only 3-4 and ship them to Norway for a reasonable cost. Some won't even ship to Norway. I've searched for days. A porsche parts number would help a lot as my dealer would get them for me quickly and cheaply.
Thanks for the suggestion. I will do that if I can't find a PN. These dowel pins are hardened and ground, so I would prefer to not have to do that if possible
I can't find an available 10 x 12 mm DIN 7 dowel pin from Porsche. Historically, p/n 900-012-024-00 was a 10 x 12 pin in Porsche's catalog. If you can use slightly longer parts, 900-012-110-00 is a 10 x 14 pin, 900-012-025-00 is a 10 x 16 pin, and both are available and should be something you can order in any quantity from a local dealership.
