Wipers not working: wiper motor or power issue?
One day the wipers stopped working, no grinding sound, no sound whatsoever when I turn on the wipers, regardless of speed setting.
A few minutes later they stated working again.
Then they shut off completely.
Before buying a new wiper motor, I want to make sure power is getting to the wiper motor. The 30A fuse is not blown.
Anyone use this type of multimeter to diagnose this? Also note that the power source of the wiper motor is coming from a module where the red arrow is pointing.
Any help is appreciated
Dear Quickie: unplug the motor from the harness, turn the wiper on, ground one side of the meter and start checking the pins for DC voltage. if it is on a regular setting, not intermittent, you should see constant voltage..If it is on intermittent, you should see the voltage fluctuate when the circuit is energized.
I tried to take the wiper/turn signal marker off the steering wheel but couldnt figure it out quickly so i only removed the white wiper wire cluster from the stalk, sprayed electronics cleaner into the holes of the white module along with the pins extending out of the stalk still connected to the steering column.
Nothing really appeared dirty but i shoved the white module cluster back in securely and the motor runs now.
I fear this turning out to be a temporary solution though.
My question is this: similar to an ignition module bypass, what wires can i manually connect to facilitate powering the wiper motor?
I may do it anyway since I haven't found any diagram or posting that tells me how to properly connect the wires independent of the stalk
The wiper motor works when dry but as the rain comes down, it stops working (when I need it).
The guys at the Indy shop thinks it's the moisture in the air that is compromising the exposed connections to the motor.
Can anyone recommend a waterproof version of RTV Clear or similar product that I can apply (preferably via spraying) to the connections that will:
a) seal them from any moisture and
b) still allow electricity to be conducted
