Wilson's thread
Old 04-03-2015, 05:21 PM
  #91
Tiger03447
Tiger03447's Avatar
Dear Noah: for a quick and dirty fix that is pretty good to keep water out, one might go to Home Depot and pick up a roll of their extreme weather HVAC silver tape...better than duct tape..used on my son's apron to hold it together for several months while I got a new apron after he hit an iced-up snowbank. It didn't lift the paint on it's removal about 3 months later...hope this helps someone..
Old 04-03-2015, 08:33 PM
  #92
psychoideas
psychoideas's Avatar
I'm pretty sure that if the four drain holes are clear, the water will escape before entering the cabin and landing on your head.
Old 04-04-2015, 11:12 AM
  #93
Noahs944
Noahs944's Avatar
Thanks brothers!
Made the decision to do surgery to adapt the rubber piece. This is the piece I cut off. I lied it actually wasn't as heavy as I thought it was. This part goes into the garbage. See ya!
Old 04-04-2015, 11:14 AM
  #94
Noahs944
Noahs944's Avatar
found this. Considered making one out of aluminum then I realized it is aluminum. Got ill looking & touching the glue & felt. Hate that stuff.
Old 04-04-2015, 11:16 AM
  #95
Noahs944
Noahs944's Avatar
The rubber fits the steel better than something I could make & with engine assembly lube it pops in place easily enough.
Old 04-04-2015, 11:20 AM
  #96
Noahs944
Noahs944's Avatar
Was able to cut the 2 mounting zip ties & loosen every clamp & pull the main fill tube up & out about 15mm.
Then I put the external exterior flap back on, but the toughest work needs to be figured out. I dunno what I'm going to do about rain.
Old 04-04-2015, 03:59 PM
  #97
Noahs944
Noahs944's Avatar
Well the mail came & for the last 2 days my car is acting up again. Terrible idle problems. Perfect timing for my DME coolant sensor connector & throttle body rebuild kit.
The connector is a NEW style that can be removed with one hand. Oh by gosh & by golly... imagine that! No more
I suspect a harness/connector related problem, as mentioned before, which is temperature sensitive. Could be wrong though.
Old 04-04-2015, 04:02 PM
  #98
Noahs944
Noahs944's Avatar
My back up plan is to install a dimmer switch on the yellow wire, which will go from sensor to DME like before but the resistor is in the middle.
Old 04-04-2015, 04:05 PM
  #99
Noahs944
Noahs944's Avatar
Here how I like to turn crappy plastic coated crimp terminals into nice small terminal. I got the hang of slicing them with a razor blade after doing about 8.
Old 04-04-2015, 04:08 PM
  #100
Noahs944
Noahs944's Avatar
Here's the majority of the throttle body bits. The only tricky part was removing the butterfly screws & then cleaning the burrs off the butterfly shaft before removal.
Old 04-04-2015, 10:40 PM
  #101
Noahs944
Noahs944's Avatar
Car's back together. Went for a mild but enjoyable drive 'neath & through the light snow. Sometimes a grey & white day is more fun than in the sun. My complaint in the past has been the roads in 3 outta 4 directions from my town are all a "grid pattern"... boring!! Don't be square man. "Hey man, don't be square alright?".
...but tonight I revisited the roads that I first learned how to motorcycle on. It was fun. Feels like a rally course more than a road course.
And to be honest the provincial government just DOUBLED the quota for speeding tickets. ****ers. And hugely increased the taxes on gasoline, smokes, alcohol. Brought back health care expenses & increased taxes on people who make decent coin.
So with this in mind, even the lowly 4 cylinder's appetite for fuel is a consideration. And of course the over-achiever-**** with a lazer gun has me & everyone else in his sights. I just shut my lazer detecter off because its more on than off & is just a buzz kill.
Sorry if I seem like a cop hater. I'm not. I worked with police officers for years & respect them. But the provincial government is a different story.
Old 04-04-2015, 11:00 PM
  #102
Noahs944
Noahs944's Avatar
The throttle body rebuild kit is KILLER. That was the most fun I've had working on my car in a long time!! If you haven't rebuilt your TB. Order the re-seal kit. It's cheap. Did I find anything wrong while I was in there?
Kind of; hard seals next to the upper & lower butterfly shaft. Also one of the small vacuum lines has the tiniest little pin hole in the main bore that I think was clogged. I sprayed everything with carb cleaner & lightly lubed the seals & bearings with engine assembly lube.
The kit came with all new hardware & the two bolts that hold the butterfly onto the shaft were in really rough shape from extraction. I was going to "peen" the ends of the bolts like Porsche does, but instead used red loctite. Hopefully it holds. Otherwise I'll be buying a new engine
Conclusion: there's a few things that can go wrong with the throttle body which will mess up your idle. This kit addresses those things. The instructions were 100% excellent & if the kit contents don't provide you with what you need then that's because your throttle body needs to be replaced not rebuilt.
So time will tell.
Old 04-04-2015, 11:28 PM
  #103
Noahs944
Noahs944's Avatar
SO I WEIGHED MY CAR TONIGHT.
-Tank was 7/8 full.
-All steel panels/all glass.
-Both seats with sliders.
W/Out driver: or possessions: 2570 lbs/1,165.73 kg.
Street legal.
I'M VERY HAPPY WITH THIS. In a year or two he'll be even lighter. And quicker.
From factory they are about 2800-2900 lbs. Kinda wished I weighed mine when it was "regular".
Here's Wilson when he was "Ol' Wilson" I miss that car. GREAT for touring!!
Old 04-04-2015, 11:37 PM
  #104
Noahs944
Noahs944's Avatar
WILSON:
Heart like 944S but attitude like a 931. I love you
Old 04-05-2015, 10:28 PM
  #105
Noahs944
Noahs944's Avatar
Now whats up?
Quick Reply: Wilson's thread
