Balance shaft alignment- is this right?
Yes, that looks as close as you're going to get it... Clearly, if that notch was at the tooth to the right or the left, if would be further away from the plastic blade.
Thanks Van. I still don't understand a posted a marked up picture in the turbo forum-
https://rennlist.com/forums/944-turb...-confused.html
That's correct. The notch you have circled in blue is where the material for the tang that slides into the unused key way comes from. It is not there as an alignment mark. The only mark is the notch at the back end of the pulley.
