968 brakes same as 951?
Originally posted by Thom
You mean the 220 hp 951 then, right ?
A 968 with the M030 sport suspension should have the big brakes though... confused yet?
Yes I would switch both front and back calipers.
I have done so on my 87 N/A. I needed to get the front steering knuckle from a 951, S2, or 968 though as the front calipers will not bolt right up. The rears will go right on though.
Originally posted by Randy_J
Yes, same as a "regular" turbo - not the M030 big brakes (928S4's) in the front. Just looked at a 968 last night with stock suspension (non M030) and it had the smaller 951 4 piston brembo brakes in front.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
968 M030 also had cross drilled rotors and a bit larger diameter rotor rear.
Originally posted by Duke
And just to confuse it a bit more, the M030 big brakes actually became standard and not part of the M030-package on the 89 - 91 models
The big brakes were indeed part of the M030 for the MY89 since the M030 was "stock" this year, not for the MY90 & MY91 though.
Sorry...I just had to!
Hehe but how do you know that they didn't remove the big brakes from the M030-package in '89 and made them standard?
The big brakes were standard on MY90 & MY91 951 but were part of the M030 on the MY90 & MY91 S2 only !
To put it another way, the M030 option on the MY90 & MY91 S2 did include the big brakes, but the M030 option on the MY90 & MY91 951 did not include the big brakes.
Cheers !
Well thanks everyone for the input, i will prolly be switching my 924S to 968 brakes front and back over the winter. I'll post the list with how it goes etc...
Thanks!
Erich Schmidt
Thanks!
Erich Schmidt
Hehe simply because non-M030 MY90 & MY91 S2 did not have the big brakes as standard.
Cheers !![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Cheers !
But, was the MY88 944 Turbo S equipped with the M030-package or was these things included in the "plain" 944 Turbo S-standard-package and then later on was put together in a sports package M030?
In that case, you could say that the MY88 Turbo S have the big brakes as standard and not as a part of a package!?
Given that the M030 of the MY86&87 951 did not have the big brakes, I believe the big brakes were reserved to 250hp 951, so the only thing we can actually say is that the M030 contents varies with the model - like you said above, the M030 of the 968 was the only M030 to include drilled discs.
