Fuel pump fuse keeps blowing:( Bad fuel pump?
Hello All,
Need your expert help again!
Yesterday my 86na stalled out and couldn’t get her started again.
I think I heard a loud noise coming from the rear passenger side a few days ago, hmmm..
I put the 3 wire jumper into the relay location -#30 #87 #87b
And again this caused the fuel pump fuse to blow!
I connected the fuel pump directly to battery and the car did start, but it stalled out. The fuel pump was very a bit noisy, and whinny. I am thinking this is a sign it is dying?
I ordered a new:
fuel pump
DME relay
reference sensor
The connector head on the reference sensor crumbled into tiny pieces. Seems this may be part of the problem too!
Question: Does any one have a part number for the short 2 wire fuel pump harness?
I am looking for the small length section that plugs into the fuel pump while the other end plugs into the longer harness that travels to the front of car
T.I.A.
Toran
I ordered a new:
fuel pump
DME relay
reference sensor
T.I.A.
Toran
Yeah, it sounds like the pump has gone south on you. Don't forget to change the fuel filter and pull the strainer to see that it's clean (it's in the tank where the fuel line is attached). If you pull the line off the tank and the fuel really pours out, your strainer should be ok. I'd recommend that your tank is as empty as possible or you're gonna have gasoline everywhere. Make sure your garage door is open or you're outside and have a fire extinguisher handy.
Unplug your O2 sensor before you pull the pump. It is on the same fuse. For some reason the sensor side of the sensor plug just falls apart over time, replace them both.
Thank you for the responses!
mytrplseven, good tip. I replaced the fuel filter and strainer about 8 months ago.
And yep I just filled the tank up too! Gonna need something to catch all that premium fluid!
Adker, another good tip, much appreciated!
Hello again,
Could use some more of that good forum support again
I replaced:
fuel pump
DME relay
distributor cap and rotor
reference sensor
Reference sensor tach bounce when attempting to start the engine
And the car still will not start. It will not turn over
The fuel pump fuse still keeps blowing.
What I have tried:
Fuel pump connected directly to battery you can hear it working and the fuel rail has pressure.
3wire jumper to 30-87-87b DOES NOT CAUSE THE NEW PUMP TO START
And still it will not start.
I have noticed that when using the 3wire jumper it is number 87b that causes the fuse to blow.
What am I missing?
I replaced:
fuel pump
DME relay
reference sensor
What I have tried:
What am I missing?
Hello Everyone,
AS ALWAYS, THANK YOU VERY MUCH FOR THE MUCH NEEDED TECH SUPPORT.
Looks like the issue was related to the wiring going from the full pump to the fuse box. I tried tracing the wires from the fuel pump toward the front of the car and lost them in the process.
Cause I needed to get back up and running(going to work). I was able to put the fuel pump on a LED toggle switch connected directly to battery. That got me up and running for sure without any problems.
This weekend will continue the hunt to replace the wiring.
At the same time that fuel pump toggle switch setup can be made to be a cool anti-theft setup too!
THANK YOU
THANK YOU
