Need help ASAP!
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
Hey all! I visited the mechanic today to pick up my car and he informed me that all of the passenger rear lights were out. Brake lights, parking lights, reverse lights, everything. Anyone know what could be causing this? I have to get this fixed so I can get the car inspected. If I have to take it down and get it inspected in Marlyand its going to cost an arm and a leg. Thanks!!
-Dan
-Dan
So, your front parking lights are working?
On my car the left side parking lights are on one fuse, the right side are on the other.
I assume you checked all the fuses, right?
Big thirst, Sore Thumbs
Napoleon
Napoleon
![](https://rennlist.com/forums/images/ranks/veteran_marine_corp.png)
There is a fuse for one side. But I agree it's probably a loose wire in the rear area. Turn on the parking lights and pull the light assembly. (It's not hard) then start fiddling and looking. Should stand out pretty quick.
When I learned troubleshooting in The Corps the instructors always said "Don't eye f*ck it" since then I have learned about 75% of the time you can see the problem pretty quick.
