Just joined the NNJR
Well after owning my 944 for a couple of years I have finally sent in my "application" and yearly dues. Looking forward to some NNJR events!
Chrsitian
Chrsitian
As a matter of fact. The company said All they need is a recipt from the body shop and a note signed by the proprietor stating that they re painted areas damaged by falling debris. I will have the car by wednesday! And yes I am looking forward to the Pricnic however the weather report is not looking good! Z-man I herd that it is very difficult to get into NNJR DE's, meaning they fill up allmost instantaneously.
Christian
Christian
Z-man my engine now leaks oil due to a bad rear main seal and I plan on replacing it sometime in the winter while doing the clutch, would I fail tech inspection for porsche club DE's due to this?
Christian
Christian
Christian:
The key to getting into DE's is to mail your application the first day the event opens! It also helps to volunteer for club stuff. (Bribery works well too!
Regarding your oil leak: if it is a significant amount of oil leaking, then yes, you'd probably fail. However, if you feel it will last until the winter, you should have no worries about passing tech.
-Z-man.
-Z-man.
If I were you, I'd get it looked at before the winter. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
As for passing tech: we'd have to look at it on a lift to see how wet the bottom is. You could be burning some of that liter of oil through the engine: it may not be all at the main seal.
-Z.
-Z.
Andy yup got the car back from the paint shop. Car came out great, however the same day my airconditioning compressor broke off. read my new thread here https://rennlist.com/forums/showthre...threadid=82452
thanks
Christian
thanks
Christian
