Cracked torque tube bellhousing... WTF?
Torque tube - transaxle bellhousing:
Anyone ever seen that one before?
I was fixing to drop the trans and it has me worried. Here's one for you more experienced guys, sorry it's lengthy but it's weird:
I was driving about a few weeks ago and suddenly I hear a whirring, wailing noise from the rear end and I lost power. I was just in 3rd, in light traffic and pulled over. CV joints checked out. Starting in 1st, 2nd, etc all resulted in no movement, just that noise.
My gut told me the diff failed which made sense since it happened in all gears, so it was either the coupler, input shaft, or final drive (and how often do you hear about coupler shearing splines in an NA car relative to diff failure). I had to be back in Waco for finals, so the car sat in Houston until I got back a few hours ago with a new trans.
Here's where it gets weird. I proceeded with caution upon inspecting the cracks, and was removing the coupler allen bolts. I took out the front-most bolt first, and when I was taking out the back bolt the coupler spun over the torque tube splines, as though they had sheared. There was little resistance - I could turn the coupler by hand despite the torque tube not moving at all.
I put the front bolt back in, and it coupled fine, no shearing (from the torque I could apply with my wrist at least). I wish I could say I slid back the coupler to inspect everything, but I never got the second allen bolt out because I broke the only extension I had that would allow me to reach it (someone had the coupler locked down too close to the trans...)
Heading out on a tool run in the morning, hoping to get feedback and pointers on this, I'll update as I progress.
One final thing - I'm still pretty sure the diff failed, regardless of the torque tube condition. I had both rear wheels up in the air, and with the trans in neutral, I spun one wheel. The trans is LSD so the other wheel should have spun, and it did not. Greatly needing a sanity check, and other ways I can verify the state of the diff without tearing the trans apart (although I plan to later on).
Anyway, I've elected to use a grinder and cut the tt bellhousing open and cut the old coupler in half. It's all being replaced.
Now that the TT is out, you can really see the cracks and how they contributed to the failure:
Not that I know of. It was tracked before I bought it, and judging by the dog ears on the TT is isn't stock my early car. I'll be making sure the replacement driveline never needs replacement (knock on wood) because this job is pretty annoying.
I did cheat for part of it, i had a truck for an extended maintenance i did on the S last year. That was by choice not need though.
