Is my k26/6 turbo fried?
I bought this 1987 951 a year ago.
it's a franken 951 from 3 donors.
blue sunroof, nose piece and rear fender lips
gold the rest of the way round
motor from another 951 after previous owner overboosted and blasted a piston through the head... or something like that...
19psi about do it?
so i've driven it with a non working turbo - boosting about 6 psi on secondary meter for the last year.
recently i installed a lindsey boost controller, found the j boot broken so replaced it also. nice and red...
car makes great power now but when the engine is hot and if you floor it... there is a hestitation, a stutter, a pop sound, then full boost
on the track last week, we saw a little puff of smoke also.
under the hood... oil all over the air flow meter, j boot, and inside the intercooler pipe, and throttle body.
under full throttle acceleration, black smoking coming out the pipe
under regular driving, i'm using about 1 quart every 1,000 kms...
by inspection i suspect that:
1. turbo is spewing oil into intercooler, intake
2. oil supply pipe (from on top) has an o-ring / seal that may be leaking
thoughts?
and recommended fix?
19psi about do it?
thoughts?
1 qt/1000km is fine, that's the porsche spec IIRC for acceptable oil use.
if theres a lot of oil then its probably turbo oil seals gone bad. might also mean your rings are going out and blowing oil into the PCV system.
