Should I bake my wheels in the oven?
Old 08-01-2003, 11:23 AM
adrian_jaye
adrian_jaye's Avatar
gas mark 6,
baste slowly, with a bbq sauce or lithium based salad (oil free) dressing
Old 08-01-2003, 11:53 AM
Tremelune
Tremelune's Avatar
What if you just let 'em cool reeeal slow? I was wondering about this a few months ago...
Old 08-01-2003, 12:07 PM
M758
M758's Avatar
I work in the aerospace industry and a routine part of the painting process on cast aluminum parts is to bake them a 200F for 60 min. This is usally done to help dry the parts and preheat so they are painted hot and to help dry them. Some magnesium parts do see 400F. These parts have been previously heat treated and these temps do not impact those heat treats. This applies to structral and non-structural parts in jet engines.
So I would guess that one can heat the wheels to 200F in prep for painting or after paint bake and it should be fine. Just let them air cool after. Remember also that r-compound race tires can see 200F tread temps.
Old 08-01-2003, 12:57 PM
Jonas Goldsmith
Jonas Goldsmith's Avatar
After a very "spirited" canyon run, I have had my front rims hot enough to the touch, that I think they could have burned me... a bad thing?
Old 08-01-2003, 01:07 PM
xsboost90
xsboost90's Avatar
what kind of paint did u use?? MOST paints nowadays will be fine, but some dont like being baked, it will kinda dull the finish. If u used a urethane u will be fine though.
Old 08-01-2003, 02:15 PM
Damian in NJ
Damian in NJ's Avatar
I'm guessing none of you guys are married, or you wouldn't even consider throwing them in the oven . . .
Old 08-01-2003, 02:58 PM
Mark Hubley
Mark Hubley's Avatar
I'm married, but I do most of the cooking. I guess that's because I also do most of the eating!
Mark (a liberated man)
Old 08-01-2003, 03:03 PM
Mark Hubley
By the way, speaking of hot wheels, I'm glad that I purchased a set of steel lug nuts prior to my DE. On the third day at the track I noticed that a guy in an 80's Carrera had his front tires on backwards. He has unidirectional tires, and the fronts were going the wrong way. It probably wouldn't have mattered much, since the track was dry, be he decided to try to swap the wheels. He broke two of his alloy lug nuts trying to get the wheels off!!! Man, they were on tight.
The general consensus of those who observed this is that the wheels/hubs/studs get hot enough on the track to make those alloy lug nuts seize. Most everyone at the track had steel lug nuts.
Old 08-01-2003, 03:14 PM
Randy_J
Randy_J's Avatar
Originally posted by Mark Hubley
......He broke two of his alloy lug nuts trying to get the wheels off!!! Man, they were on tight.
A little dab of copper anti seize before torquing to 96 LF helps.... snapping alloy nuts is bad enough, but wait til you see what it's like to get a seized wire wheel rim off a knock off hub! Well, I guess it's about the same hassle.
BTW, HOW WOULD you get a broken alloy nut off, especially for some of the wheels that have the nuts deep inside a hole to start with??/
Old 08-01-2003, 06:17 PM
Mark Hubley
There was discussion about using a punch or chisel with a hammer to remove the remaining parts of the nuts.
Ouch!!! I hope nobody has to go after my nuts with a punch!!!
Old 08-01-2003, 06:31 PM
SidViscous
Big thirst, Sore Thumbs
Napoleon
SidViscous's Avatar
See my sig.
Use a hole saw to get them off.
Quick Reply: Should I bake my wheels in the oven?
