Talk to me about fuel rails!!! URGENT!
Old 04-20-2014, 11:30 AM
lart951
Basic Sponsor
lart951's Avatar
Originally Posted by william_b_noble
I have the rail from an 87 S sitting here if you need it, but not too close to you
the 87 S is a totally different rail it wont fit the 951.
Old 04-20-2014, 07:33 PM
911racer
911racer's Avatar
I have a Lindsey set up for sale for $415 plus shipping.
Ed
Old 04-28-2014, 12:04 AM
Adker
Adker's Avatar
Originally Posted by teamking
I like what they've done! It seems smoother, safer, faster, and racier all at the same time. I will miss the Oak Tree at the start/finish line, but I understand why they did it. I like the fact that exiting both 3 and Oak Tree, you have the option to cross the rumble strip, although that may or may not be faster.
Here is video:
New Paving at VIR - 2.13.1 in a 944 Turbo - YouTube
Thanks for the video. Good lap.
Lines looks the same but it is weird not seeing corner workers right at the old oak tree corner (feet away) protected by the large oak tree. Looks smooth, lap time are better, great track. I don't think the tree was removed, it came down in a storm.
Old 04-28-2014, 12:41 PM
konakat
konakat's Avatar
Those were some nice lateral acceleration numbers in your video. Looks like you have a nice setup.
Old 04-30-2014, 11:35 AM
teamking
teamking's Avatar
Yes, Oak Tree corner is a little bit more difficult without the visual references, plus they've widened it at the entrance and exit. So it is just a question of getting used to it.
The other oak tree that I will miss is the one that was on the start/finish line. By removing it, they were able to push the guardrail back which is certainly safer, if less aesthetically pleasing.
Old 04-30-2014, 11:42 AM
teamking
teamking's Avatar
Thanks! The 944 Turbo, with some suspension work, certainly represents a great bang for the buck.
Doing DE's though, is starting to get frustrating because of the lack of straight line acceleration. Can't tell you how often I get behind a Mustang or Cayman in the twisties and then they leave me on the following straight. I immediately catch up in the braking zone. Rinse and repeat.
Maybe it is just a mis-perception on my part, but it seems like I get a blue flag at the first corner a fast car catches me (and I was checking my mirrors so I knew they were coming and was readying to give them a point by), whereas I can follow another car for a full lap and they never get a blue flag. Are corner workers biased against 944's?!?!? (Woe is me!)
Old 05-01-2014, 02:00 AM
mj951
mj951's Avatar
Great video, thanks for sharing.
What type of data / video set up is that, looks great.
I assume you can download the data and graph? Would be interested to learn more about it, thanks. Would also be curious to learn what suspension mods you've done, considering some myself.
Old 05-01-2014, 02:03 AM
Dougs951S
Dougs951S's Avatar
is your motor stock? straight line acceleration isnt something you hear most 951 owners complaining about. With just a chip and a 3 bar FPR you'd be walking away from a cayman or mustang. It's super easy and cheap to get these cars to 280ish rwhp and 300+ rwtq.
Old 05-01-2014, 02:25 AM
Chunkerz
Chunkerz's Avatar
I like how you have your instrument cluster set up. I used mine like that for almost 2 months after my daily driver died and my 944 was my only form of transportation.
Old 05-01-2014, 03:17 PM
teamking
teamking's Avatar
Thanks!
Here are my mods:
  • Guards LSD
  • Paragon Race clutch (p/n PP951CLUTCHKITRACE)
  • Racer's Edge Lower Control Arms (early)
  • Racer's Edge Camber Plates
  • Racer's Edge Caster Blocks
  • Racer's Edge Rear Elephant bushings
  • Racer's Edge inner and outter Delrin Bushings
  • LEDA dampers
  • Front Hypercoil 500 lb springs (8" x 2.5")
  • Rear Hypercoil 600 lb springs (8" x 2.25") plus helpers
  • 944S2 Spindles/Hubs/Front rotors
  • stock front swaybar (22.5mm)
  • 19mm adjustable rear sway bar (Porsche)
  • Strut tower brace (KLA)
  • Driver's seat: Recaro SPG Profi
  • Passenger's seat: Sparco Sprint V
  • Driver's harness: Schroth 2013
  • Passenger's harness: Schroth 2013
  • Fire System: Spa AFFF MFM-400S
  • Custom rollbar (Kenny Shreves / Werkstatt)
  • Gutted interior
  • Sunroof delete
  • Fuchs 7"/8" x 16" early offset
  • Hoosier R6 245/45/16
  • Stainless steel brake lines
  • PFC 97 brake pads
  • Shaved rear wiper
  • Upgraded camber bolts
  • VDO oil temp gauge
  • Lindsay fuel lines
  • AIM Solo data acq
  • XD1080 camera w/ hardwired remote
  • Weight <2700 plus driver
So, I combine the data off the Solo with the video off the XD1080 with RaceRender. Now that I've done it a lot, it only takes me about 3 or 4 minutes to sync the data and video.
And there is plenty of data to be analyzed in RaceStudio, that comes with the Solo.
Although, I think if I had it to do over today, I would start with a SmartyCam HD and build from there.
Old 05-01-2014, 03:19 PM
teamking
teamking's Avatar
Yeah, I've been trying not to do anything that wouldn't be legal in '44 Super Cup. But maybe I ought to reconsider unless and until I start racing.
Old 05-01-2014, 03:21 PM
teamking
teamking's Avatar
It was amazing how heave the dash was. Must have been 50 pounds! I'm all about free speed!
Old 05-01-2014, 03:58 PM
PorscheDoc
PorscheDoc's Avatar
Go with a new aftermarket rail. We see so many 944 rails failing now, I just wouldn't trust a used rail anymore.
Old 05-02-2014, 12:09 AM
mj951
mj951's Avatar
Nice setup, again thanks for sharing.
Thanks!
Here are my mods:
  • Guards LSD
  • LEDA dampers
  • Gutted interior
  • Sunroof delete
  • PFC 97 brake pads
  • Shaved rear wiper
  • AIM Solo data acq
Old 05-04-2014, 08:52 PM
Adker
Adker's Avatar
I was using the tree for a visual marker to determine where the kink was on the straight. That kink at speed can be a SOB if you turn in it. Going to have to use the buildings now...thanks for the heads up.
Quick Reply: Talk to me about fuel rails!!! URGENT!
