Police sirin? Turbo noise?
#31
UPDATE:
I have the BOV in hand and can blow through the vac hole and the right angle hole. I shoulden't be able to blow through ANY hole right??
Chris
Chris
#33
Well.. the turbo has about 1/32 or so play up down left and right... and about the same ammount in and out... Is this too much? I need to put in the new BOV and see if that fixes some of the noise (my feeling is that it will). Ill keep my fingers crossed... BTW is $70 too much to pay for the SAAB BOV?
Chris
Chris
#36
Hopefully it will come in around 4:30 today. I'll slap it on and see how that works! Now if only I could find a new intake boot for under $70!!
Jeez its only rubber!!
#37
Just put the bypass valve in... not much difference in boost time - or spool time... seems the same... oh well -- it seems to have silenced some of the noise. ill have to look for more leaks. back to the garage
#39
Well... I still think I have a leak on the high pressure side of my intake... Like I said, I had the same noise when my 79' 924 with BAE turbo kit would get a crack in the boot on the high pressure side... anyone have good way of testing for leaks in innercooler, etc... I can pressurize it with a tire pump but cannot cap one side and don't have a fitting to restrict the other side small enough to fit my tire pump-
#40
The best way to pressurize I found was to remove the AFM box at the end of the J-boot, plug the J-boot with an oil filter or fuel filter. Then plug any open connections with bolts and a zip tie. You should also plug the exhaust pipe if possible (i used some industrial shrink wrap and zip ties). Then i hooked up the air compressor with my tire filler connection and filled it to about 5psi. I could hear my leak right away.
#43
Originally posted by Velvet951
The noise is not there when you rev the car, only when boost is building. It sounds like sucking "whistley" air!?!?!?!?!
I hope this means my car is OK, and therefore your car is OK, too!
Ron
#44
Still using the stock intake... I can really hear the intake though?? I just installed a new air sensor to turbo boot and everything is the same... I heard the exact same sound on a new turbo eclipse... I'm going to do another pressure test now...
#45
Hmm, I thought that turbo mike said that no movement was acceptable? In and out? thrust wise? You said you had movement? seems like a bad turbo? just what i read...
