944 fuel pump
Not sure if this helps...
Electric fuel pump delivery rate: at least 850 cc / 30 sec.
Fuel pressure (engine stopped)
Fuel pump bridged: 2.5 +/- 0.2 bar
Idle speed value: approx. 2 bar
Leak test:
Min. pressure after 20 minutes: 1 bar
Hope this is what you were looking for.
Leak test:
Oops. Add one more flavor for later cars.
Fuel pressure (measured ahead of the catalytic converter and with the Lambda sensor plug disconnected): 750 cc/ 30 sec.
I'm not sure on the flow#s, but PET shows different part #s for the NA and turbo pumps. I wasn't going to trust a 15 year old pump that MIGHT be up to the job in new condition. I plan to mod, so I just went to the BIG Lindsey pump.
thats what i was going to do andy but i'm going over my budget, and time limit so i think i'll get an air/fuel gauge as the 2nd one in the pod, i was wondering what to get anyways. Thanks, that helps dave
Drive-by provocation guy
What is the psi and cost of the lindsey pump??
Anyone know of any OEM fuel pumps that are about 60psi or higher??? I don;t care what year make or model, just high psi and good cost.
I got the Lindsey BIG pump, I think it was about 160 bucks. I haven't run it yet. I'm also not too sure what the #s were for it, but it'll support more than the engine will, atleast stock.
I have a pump off of a 86 951 that I need to sell, if anyone is interested.
toddandcharity@peoplepc.com
