help no start
Hi guys,
Just bought my first 87 944 na. I drove it about a hundred miles then parked it in the garage. Then tried
to start it one cold morning and it wouldnt fire just turned over, batterry died pretty quick. Next weekened changed the oil and charged battery. Still only turns over no fire. Read the posts on here for about a week and this is where im at.
Changed plugs .7 gap (new plugs)
Checked spark good
Checked gas at rail good
Replaced DME relay
I have tach bounce.
It seems to be sucking air but car has after market cold air intake
Sprayed starter fluid in cylinders but it only putted slightly.
Changed battery
Jumped dme with paper clip heard gas pump sounded like injectors working. Stilll no fire
Checked spark good
Replaced DME relay
I have tach bounce.
Changed battery
You need 3 things...fuel, spark, and compression.
What does "checked spark good" mean? You've verified spark at each plug while cranking? Have you verified primary [0.4-0.6 ohms] and secondary [5.0-7.2 kohms] resistance at the coil?
What does "checked gas at rail good" mean? You pulled the end cap, cranked for thirty seconds, and verified the pump discharged the specified 850 cc of fuel into a container? Ideally, you should verify your fuel pressure at the rail. At this point, I would pull the rail with the injectors attached to see if they are firing and have similar spray patterns while cranking.
"Replaced DME relay"...with a new or used one? With a factory or aftermarket part?
Have you verified compression? I would take 5 minutes, pull the front covers, and verify your cam belt is still in one piece.
Let us know what you find.
take your old DME that you know used to work, take the cover off of it and look at the circuit board - look for cracks in the solder where the upper relay attaches - if there are cracks, resolder and try that relay.
