Mobil 1 Synthetic ATF for Power Steering
Anyone using Mobil 1 ATF for Power Steering? I know several people talk about synthetic PS fluid.
1. Do you have to remove all traces of the dino ATF before switching? Is is OK to mix the dino and synthetic?
2. How did you remove all traces of the dino ATF before switching if required?
Thanks!
Off to work on electricals now....
Thanks!
You want to use Porsche synthetic power steering fluid, I forget the name. It starts with a P...Pentosin maybe?
ATF will swell the lines and cause leaks says my mech.
Andrew, I'm switching over to all synthetics in the car except for brake fluid. Very pleased with Mobil 1 15W50 engine oil. want to swtich to the Mobil1 ATF (says it is a direct replacement for Dexron III), and as soon as my 17MM hex socket shows up in a day or 2, the transaxle gets a fill with Redline MT90 synthetic.
I can't see a reason not to use it. Just remember that the synthetic may swell any suspect seals and may cause a leak.
I use Redline Synthetic ATF in mine and have had no problems - used it since my rack rebuild about 3 years ago.
BTW, I'm investigating Whistler... *may* be able to make it.
Good Luck!
Good Luck!
Good Luck!
Good Luck!
GREAT news on Whistler! If you've never attended, it's a blast. Great people, terrific venue, and lots of P Cars.
Let me know if you are attending - rather than the banquet, we're thinking of a BBQ for 924/944/951/968 people on Saturday night. I've had enough $44 rubber chicken for a lifetime! You're welcome to come to the BBQ of course, since I just know that you'll be bringing the Paragon goody bags again.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
BTW, I need sunroof gears for BOTH the 944NA and 951S! They both blew out this week! Must be the heat.
Disconnect the lower hose from the pump and work the steering back and forth with the engine running. That works pretty well - make s good sized mess too. Don't do it for long or risk damaging the pump.
Been to Whistler a few times - only once for the PCA thing. Should know next week sometime. Yeah, I could certainly skip the rubber chicken... I'm more of a burgers and brats type.
