Did you connect back the crank angle and position sensors back? Had this happened to me first time o took of intake manifold. I just forgot to connect those two connections next to the firewall..
no other car is beckoning. Crank no start was due to a fault in the injector wiring harness. Now it starts right up. having timing belt changed for precautionary measures
the timing belt is not hard to change, just follow the instructions, change the tension rollers too. If you could fix the injector problem, you can do the timing belt
