Timing belt teeth mising
1987 924s replaced intake manifold gaskets per minor vacuum leak. Ran fine for 40k miles. Since i put it back together it will not not start? There are a couple teeth missing off timing belt. A mechanic told me it jumped time and huge repair bill because a couple teeth missing off of timing belt? But it ran fine prior to manifold gasket job? Does a couple teeth missing off timing belt mean major trouble for sure??
If they are not side by side then It only jumped a max of one tooth, I would have a Trustworthy shop do the belts if your not capable, I'd caution against trying to start it if the belt is that bad, Take it to someone that is honest and not hurting for work enough to tell you that the head needs rebuilt if it doesn't
My guess is that if this happened right after a manifold job, that timing isn't your issue
It ran fine for 40k miles since when? Since the last timing belt? Since the manifold gasket was replaced? Before the manifold gasket was replaced?
I wouldn't even do a compression test... I'd turn it over by hand to TDC and see where the camshaft mark is. *If* it's in the right place, then I'd do a compression test.
I know I'm conservative on this, but 3 years or 30k miles is a good timing belt interval.
...and you are saying you saw this and didn't change it?
...or it could have jumped one tooth per revolution.
Good advise, but I would still change the belt before doing a compression check, why take a chance with the old belt, it's obviously badly degraded.
Team Owner
From: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
see post providing my advice on the subject in the other thread you started on this exact subject. You will get better advice if you only start one thread per subject. And, yes, you are 100% foolish if you don't fix this immediately and hope you still have compression. If you don't, a valve job is a grand if you do your own labor. if you cant afford that, you now own a parts car. take it apart and sell it piece by piece and be more alert next time.
gee thanks.i guess you are laughing at my expense. Logic is.the car ran fine with a little misfire due to vacuum leak. Fixed the vacuum leak. Now crank no start. In trouble shooting found a couple teeth missing off the timing belt. Asked a question about this and possible link to crank no start. By no means is that moronic.
