doing vacuum lines... what else should i be doing??
i'm in the process of replacing the vacuum lines and all cooling hoses on the car, so i'm trying to kill as many birds as possible with this one stone. since the intake is coming off, what else should I look to do due to access?
planning:
small diameter vacuum hoses
AOS/cycling valve hose replacement
ISV/venturi delete hoses (with new stabilizer mounts)
heater control valve
thermostat
suggestions for other worthwhile replacements/upgrades? i'm not planning on replacing the ISV or cycling valve, at the moment.
planning:
thermostat
i also did a throttle body reseal, had a couple of o-rings that we completely gone.
I used this kit:
http://www.arnnworx.com/catalog/inde...dddc6ab5e317de
solved the remaining vacuum leak issues I had.
*** NOTE- I probably posted from my iPad, please excuse any typos, bad punctuation or odd grammar, if it is unreadable, it probably was posted from my iPhone.
I used this kit:
i also did a throttle body reseal, had a couple of o-rings that were completely gone. I used this kit: http://www.arnnworx.com/catalog/inde...dddc6ab5e317de solved the remaining vacuum leak issues I had. *** NOTE- I probably posted from my iPad, please excuse any typos, bad punctuation or odd grammar, if it is unreadable, it probably was posted from my iPhone.
any thoughts on what the typical turnaround is on the injector cleaning? the car is already going to be down longer than expected. very good idea though and had considered it. with everything off, i guess i may as well.
I used this kit:
I used this kit:
Not really in the area per se, but a new thermofan switch that matches the temp of your thermostat. It's one of the cheaper jobs, and no coolant in the system means it'll be the easiest job.
thermofan switch already in hand. thanks.
really trying to cover my bases on this one. at this rate, i might as well wait until my new motor mounts arrive and raise the motor while it's so much lighter.
still trying to track down a power steering leak and the coolant leak, which i now think may be in the area of the radiator.
951s certainly aren't boring to own!!!
I used this kit:
I used this kit:
About a week. If I remember correctly from years ago, I FedxEx'd them out on a monday and had them in hand via FedEx on friday. I called them ahead to tell them I was under a time crunch which might have helped.
