Front control arms and clunking.
By "knocking when I brake", do you mean you hear a/one clunk when you brake, or you get a clunk, clunk, clunk? Does it happen all the time, or only under certain conditions? When you installed front dampers, did you replace the strut bushings? Could your springs be binding and then releasing under braking? How old are your castor blocks?
Will, how often do you hear/feel this clunk? Under what conditions? If you can feel the clunk in the brake pedal, I suspect that would be direct feedback, through your hydraulic system, from your pads/calipers/rotors.
Have you ever had your calipers rebuilt? Do your pads/pistons/calipers look normal? Are your rotors seated/mounted properly?
I purchased a set of big reds and rotors etc.....just haven't gotten around to installing them. I was going to look around while doing the brakes. Crossing my fingers.....it really drives me nuts. Not sure what else it would be. It's a very noticeable pop/clunk. Again.....has been there for years and hasn't gotten any worse.
Figured some stuff out today.
Jacked the car up to take a look, and shook the wheel (hands at 9 and 3) and watched what moved. Turns out the castor blocks were shifting way far.
.....the nuts were also on finger-tight. >.>
So we tightened them back down and lo and behold: no more clunking. Not at high or low speeds, and not when turning. (That wasn't a symptom before, but is good to know it still isn't. Lol)
The problem being fixed, we got bored and made a control arm brace. I'll post pics later this week. It's simple, and we've got more work to do, but for mark one, it's not bad.
Kyle, happy to hear you resolved your issue. Well done.
Will, I recommend you
What condition is your suspension in? Kyle was diagnosing his problem after a substantial refresh [rack, tie rods, ball joints, bearings, dampers, sway bar/control arm bushings].
Have you checked the simple things...loose battery, frozen strut, binding spring?
Great to hear you found the source of the clunk! Always a good feeling take care of stuff like this....and at no cost!
Thanks for the advice Allen. The idea of a frozen strut has me intrigued. The car does feel like it sits stiff....and I will occasionally get a pop when pulling out of my barn at low speeds. Hmmmm......
Is the sway bar wacking something? I have that problem right now because the A/C compressor is wacking the swaybar since the stiffening brackets I got push it forward a little bit.
We suspect the "bam" was the frozen strut, compressed from normal driving, releasing, due to internal shock pressure. The "garage door spring" sound effect was probably associated with the car's torsion bar suspension.
Alright guys, I finally got to a proper computer and have uploaded a picture of this very bootleg brace we made: http://imgur.com/kAD4cvh
Any interest in getting one of your own if we can make it nicer/prettier? We might make them as a matched pair with a strut tower brace, and make it really affordable.
Thanks.
Rebuild your ball joints.
Audi, you haven't given us much to go on.
When did this start happening? Subsequent to any maintenance that was performed? Intermittent clunk...or intermittent clunk, clunk, clunk?
And while you're in the driveway investigating, lean on each fender and bounce the car? Do both sides/dampers respond in the same manner?
