88 944S flywheel & clutch
time to replace the clutch friction plate. Looking at the " Ranger " clutch option, modified some bolts to head thickness of .156". Not enough clearance will need to grind more off. In the mean time i removed the flywheel and found it to be cracked in a few places as well as worn from the rivets of the friction plate.
Can someone tell me what min thickness for the flywheel is ?
What flywheel will work? Are all 2.5 motor flywheels the same?
What and how do you remove the square toothed ring from the outside of the fly wheel?
And lastly does anyone have a good used flywheel for a reasonable cost. This car is almost $100 from the scrap yard.
There's a number of flywheels on ebay and I'd recommend not trying to re-invent the wheel, so to speak. It just makes sense, both time-wise and money-wise to simply replace with what works off the shelf. In recent days I've seen both clutch plates and flywheels for sale.
I take that back i did find one for $700 +
Proprietoristicly Refined
https://rennlist.com/forums/924-931-...ase-plans.html
...do not do the cheap clutch replacement.
If the car is not worth the money to fix -----sell it for what you can get "as is".
You're just wasting money and aggravation.
J_AZ
I have a spare you can have cheap, 7 of the 9 bolt holes have damage but
still hold a bolt. You could helicoil of take your chances. Hows $40plus shipping.
Steve
Steve
DC was $200 for the type i have 944online has one for less than $100. i will resurface it at work. Big news is i found a new center force clutch disc on amazon for $125 w/free shipping. Problem is i have ordered both and still waiting on shipping info for both today is the 4th day since ordered.
Hey OP, I have an excellent condition Flywheel, PP, and Disc if you're interested.
I'm happy to let the go cheap to a guy in need. Roughly 5k miles on them. Little surface rust.
