88 944s wont move making worst case plans
I plan to look tonight at my sons 944s which doesnt move in gear and running. I can push it easily in gear and have googled up some possible causes. I can only hope the bolts fell out of the coupler but plan for the worst. SO my questions are
What 5 speeds, rear pinions & rings, torque tubes are interchangable with an 88.
ALso if there are any other owners in the Cincinnati area willing to share information and parts please drop me a PM. thanks to all
You're saying that with the car in gear, there is no connection with the engine? e.g. the engine doesn't provide locomotion while it's running; and there is no resistance when the engine is stopped?
Sound to me like you have something between the flywheel and the rear wheels broken.
I'd start by looking at CV joint connection... then move up to the driveshaft/transmission coupler... then move up to the clutch end of the driveshaft... and finally a destroyed clutch disk.
But, I bet a dollar it's CV joints.
Your best friend for trouble shooting any problems with your 944 will be this one www.clarks-garage.com once on site enter (Garage Shop Manual) click on letter "T" scroll down to "Trouble shooting" & in your case it will be TS-05 Manual Tramsmission.GL
Having done the clutch job which involves removing all the stuff from the flywheel to removing the transaxle and cv joints, and since there's an easy access point to the coupler, I'd put the car up on jack stands, see if the rear wheels will turn (both individually) with the transmission in neutral. Listen for driveline noise. Next, try it with the car in gear. Have someone hold one wheel from turning and turn the other (broken clutch check).If U get rotation, How old is the clutch? Is it rubber centered? If so put your finger inside the inspection hole and check for rubber pieces. If it's gone, which I suspect as a strong possitility, then it's a chance to go to my favorite choice: a sachs spring centered clutch kit. If the clutch is indicating that it's ok, then pull the trapexoid-shaped rubber plug and the round plug on the side of the transaxle bell housing so you can see the allen bolts on the coupling. Leave the car in neutral and turn the engine with a wrench and 24mm socket on the crank shaft nut until easy access to the coupling bolts. Check that the bolts are there and tight.
Unecessary stress on the trans can blow the ring and pinion. If you hear any crunchy metallic sounds from the back it could be the R&P. That could be the cause, although unlikely.
A whole dollar guys. Van is really going to town here!
Check all this stuff, but check the CV's first.
All be safe, have a good one!
Cheers
Hey, Dollar bets have a long and awesome history. Don't rag on them.
http://www.youtube.com/watch?v=nfRXivM-Qdw#t=40s
And the winner of the dollar is???????
VAN
We just replaced the passanger side axel on saturday he drove approximately 75 miles total till it failed at the wheel. Jacked up the back rotated the drivers side and could see the axel move, boot twist on the passanger got about a half a rotation till the wheel moved.
Of course Autozone would not do a thing to compensate for the $120 tow bill, not even discount the replacement part.
Thanks to all good to see he has a good support team should a problem arise.
VAN
ok got the replacement from rock auto appears to be a nice unot compared to autozone. Installed unit and same thing can see axel move but joint no move . can move tire/wheel by hand . I s there an inner side if i am correct in my thinking you can swirch axels around the is no inner outer. If this is the case i am having hard time with two defects in a row.
Broken stub axle, perhaps. That's the flange that the outer side of the axle bolt to and it's what goes through the wheel bearing. The stub axle is splined and threaded on the outside, and goes inside the wheel hub. The wheel hub is what hold the brake rotor and wheel on.
I've seen broken stub axles, although it's somewhat rare.
