Windshield Washer Nozzle
Old Aug 4, 2001 | 10:26 AM
Mal 89 944 Turbo's Avatar
Mal 89 944 Turbo
Post Windshield Washer Nozzle
One of my nozzles is not working and appears to be clogged. When I look at it, I see 2 wires going into the assembly along with the fluid hose. What is their function? Has anyone had experience fixing this assembly?
Old Aug 4, 2001 | 10:35 AM
Untier's Avatar
Untier
Post
the wires are for the heater and your check valve is stuck shut
Old Aug 4, 2001 | 12:11 PM
Flormat's Avatar
Flormat
Post
Soak the check valve in water for a while and reconnect it.
Old Aug 6, 2001 | 09:51 AM
Tom R.'s Avatar
Tom R.
Post
Where is the check valve? I have the same problem with my passenger nozzle, and the wire for the heater clips attaches on the driver's side. Do I have to tie a drag line to the wire to get it out, and back in?
Old Aug 6, 2001 | 09:54 AM
Untier's Avatar
Untier
Post
the check is built into the nozzel. should be enough wire, try harder.
Old Aug 8, 2001 | 03:04 AM
TimC's Avatar
TimC
Post
Hmmm. Would this problem also be a cause for intermittent spray out of one side? The right side sprays very strongly, but the left sometimes manages a little spurt (please no money shot jokes other than this one) before shutting off, and at other times is utterly impotent. Doesn't sound really like the same symptom. What is the check valve's function? Keeping fluid from spraying when the unit is too cold/frozen shut?
Thanks,
T
Old Aug 8, 2001 | 05:33 AM
John 944S2's Avatar
John 944S2
Post
FWIW,
I have had problems with these valves recently, to quote, I had the little squirt problem.
I replaced both of them for about £10 ($15). They can be replaced in about 30 mins and there is no need to remove the heater wires, just replace the plastic valves. These can be identified by the T-piece and L-piece parts attached to the water hoses just below the bonnet jets.
Everything works fine now.
Best of luck
John
Old Aug 8, 2001 | 02:41 PM
Manning's Avatar
Manning
Post
I reckon replacing the check valves will keep the washer fluid from dribbling down my hood all the time then too, huh?
