Flywheel Bolt Found Under Car this morning
Old 08-21-2013 | 09:59 AM
PorscheFanatic202's Avatar
PorscheFanatic202
Default Flywheel Bolt Found Under Car this morning
As I was pulling out of the garage this morning, I found a present left for me under the car. A flywheel bolt. I have recently done the clutch and resurfaced the flywheel. I got all new flywheel bolts and thought I put enough red loctite on there, but my real question is are there any ways for the bolts to get out from between the flywheel, the clutch disc and pressure plate? I feel like something would have scraped first and made awful noises.
My second thought to where this bolt came from was possibly an extra old bolt had been placed somewhere in the engine bay/ ontop of the exhaust somehow and finally has come to rest off the car. Anyway, if you have had experience with these bolts coming off please enlighten me.
Old 08-21-2013 | 10:01 AM
PorscheFanatic202
Basically i'm asking if it is even possible for a bolt (if it came loose and dethreaded itself) to actually fall out of that volume between the flywheel/clutch/pressure plate.
Old 08-21-2013 | 10:27 AM
V2Rocket's Avatar
V2Rocket
Rainman
Does it look new?
Old 08-21-2013 | 10:30 AM
mytrplseven's Avatar
mytrplseven
Does it look broken?
Old 08-21-2013 | 11:03 AM
Mueller944s2's Avatar
Mueller944s2
somehow I think it's probably one of the old ones. I had them all over the place when I did mine.
Old 08-21-2013 | 11:35 AM
PorscheFanatic202
Looks older. I assumed it didn't come from the flywheel and drove into work today and my flywheel exploded.... Just kidding. Probably came from the engine bay.
Old 08-21-2013 | 11:47 AM
Van's Avatar
Van
I think you're fine. I agree, I don't think it could come out.
Old 08-21-2013 | 12:26 PM
extanker's Avatar
extanker
i dont think it came out either,at the very least you would have heard it. on the humor side are you an aircraft mechanic? eeeekkkk
Old 08-21-2013 | 01:35 PM
StoogeMoe's Avatar
StoogeMoe
I think it would be too big to come out. Just sloppy cleanup.
Why did you use red loctite? You're going to have a killer time getting them out when it comes time. That's what torque specs are for.
Old 08-21-2013 | 02:10 PM
PorscheFanatic202
Not sure. Maybe it was blue. No aircraft mechanic but I am almost a pilot. One more month.
Old 08-21-2013 | 05:38 PM
jeffrsmith's Avatar
jeffrsmith
Air tools will take care of that!
Old 08-21-2013 | 07:28 PM
PorscheFanatic202
Was thinking about saying that
Old 08-22-2013 | 01:31 AM
Grandpa#3's Avatar
Grandpa#3
From: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
Who have you P.O. lately? Maybe they threw a bolt into your garage just to mess with your mind.
Cheers,
Larry
Old 08-22-2013 | 03:12 AM
william_b_noble's Avatar
william_b_noble
"Air tools will take care of that!"
actually, air tools may well shear the bolts off if you used Red.... heat will take care of it, but you shouldn't use locktite on these bolts.
Old 08-22-2013 | 04:49 AM
Cuda911's Avatar
Cuda911
Seems highly improbable that the bolt could work its way out.
Quick Reply: Flywheel Bolt Found Under Car this morning
