netscape problem
![Angry](https://rennlist.com/forums/images/icons/icon8.gif)
does anyone else have problems accessing these boards with netscape? it used to work fine for me, but since last week, any time i click a link for a particular web board, instead of getting that board, i get a dialog box to save some cgi file. i don't have this problem when using ie.
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
I use Netscape 4.7x under win98, Linux and Solaris (try that using IE
) with no problems accessing this board.
As for the browser wars, I think of MS = Taliban, and Unix = Northern Alliance -- holding a defensive position but not completely beaten. If we could just get USAF air support...
-Mark 86 944 NA
-Mark 86 944 NA
I'm hitting it with NS4 right now and although slow seems to work fine. The fact that it doesn't know how to interpret a cgi file extension sounds to me like the associated file types got whacked. I would try to reinstall NS and see if the problem is resolved. If that doesn't work then I would uninstall and reinstall NS.
FWIW, If you really dislike using MS written software you might want to try Opera. It seems to work very well.
Lifetime Member
Lifetime Member
Turn this into a flaming about browsers...
Come on old fellas, IE won. From a web design standpoint, I don't think you all know just how much of a pain it is to build an awesome website then view it in Nutscrape and it looks like dung.
If Netscape will just adhere to the standards.... they always seem to be portrayed as the "little guy" (hence, Norther Alliance) - people - they are owned by AOL/Time Warner. Not quite little...
Originally posted by Matt Olde:
<STRONG>Turn this into a flaming about browsers...
If Netscape will just adhere to the standards.... they always seem to be portrayed as the "little guy" (hence, Norther Alliance) - people - they are owned by AOL/Time Warner. Not quite little...</STRONG>
BTW, Mozilla is Netscape - back in the early days, that was how you were supposed to pronounce "NETSCAPE" - what a goofy idea that was.
Ok I'm in with the browser war....
Netscape is over, it's been over for a couple years. At our site we still have approx 5% that use Natscape, and they have 95% of the problems. I use a Mac most of the time and Mozilla, opera, icab, and IE are a pleasure to use, Netscape will vomit on most complicated pages.
I hate MS as much as the next guy, but hanging on the Netscape is not the answer, try some of the others. Opera and Mozilla are available for winbloz and are even better than IE.
Netscap adheres to strict standards to it's detriment. If a misplaced character causes the browser to incorrectly display a page that 3 or 4 other browsers can overcome I consider that a problem for Netscape, not a plus for it’s strict loyalty to perfect HTML.
Lifetime Member
Lifetime Member
Netscape 6 crashed on 3 seperate installation tries on two different computers, on running 98 and one ME. Go figure. After it finally installed properly it crashes when I run the program. Therefore, I revert back to NS4.5 for design purposes.
Not good HTML? I disagree. They won't let you nest more then 4 tables before it starts to slow, and at 5 or 6 it's done for. I don't think that's bad design work. I also don't think you need that many, but really, should it crash the users' computer?
Funniest thing I ever saw was back when I was die-hard Nutscrape fan even Nutscrape.com would sometimes looked like crap. This isn't about making your site using "only notepad" because frankly, that's stupid. Therefore they need to keep up with the times, plain and simple.
FYI: MSN.com freezes up in Netscape - go figure.
Take a peek at this: http://www.projectseven.com/grafitti...2001/index.htm
-Matt
-Matt
<STRONG>Netscape 6 crashed on 3 seperate installation tries on two different computers, on running 98 and one ME. Go figure. After it finally installed properly it crashes when I run the program.
-Matt</STRONG>
-Matt</STRONG>
As for writing HTML in textpad or whatever, this is not an argument I find remotely accurate. Its a text based language plain and simple. I am not telling you to write Java in textpad but damn, if you are a Java developer you sure better be able to write it with a pen and paper less you aren't a Java developer. Same goes for Perl and C and undoubtedly XML and HTML in my humble opinion.
I can't tell you how much I hate cleaning up the crap that someone did using Dream Weaver or Front Page. HTML editors going back as far as NaviPress have always been terribly bad at adding unneeded tags and horrible at formatting anything that looks like a developer did the work.
I'd suggest that writing "static" html is behind the times.
well, i won't pretend to know as much about the guts of my browsers as some of you guys; i stopped caring about all that stuff when the web stopped being cool. i'll just say that i like netscape better for stupid, simple reasons: pages look cleaner and you can get rid of the stupid "illiterate safe" graphics on the toolbar buttons. the right-click menu is better and it sends your browsing records to aol, not microsoft.
and honestly i think that a lot of the netscape "flakyness" is attributable to microsoft programmers (not engineers--writing code is NOT engineering) putting malicious behaviour into their web server, proxy, and java code. ever tried using hotmail with netscape? it's many times slower. yeah, this could be because netscape sucks, but i'm inclined to beleive that somewhere a bunch of programmers reverse engineered netscape and figured out how to write java that would slow it down, put said code into hotmail (which runs on UNIX computers, btw... NT is still to slow) and then specifically designed ie to be immune to that. i'm sure the same thing goes on with every firewall i have to go through and all those microsoft web servers.
Having written proxy servers, I know that Netscape conforms to HTTP standards far better than IE.
Also, having written web pages, I know that versions of Netscape that pre-date 6.0 release (NOT THE BETA VERSIONS) do not handle CSS worth a damn.
