Check this out... My timing belt rubbing, lost a 3rd its width!!!
Today I got
My Custom Title
My Custom Title
From: Las Cruces NM (NMSU) / Fountain Hills AZ (home)
This isn't necessarily a thread asking for help but more like something crazy I figured I'd share. Feel free to speculate on what might be causing this as I check out the car. Actually, more like as my dad checks out the car, as I am in final stages of packing for college.
This is perfectly bad timing for me... (No pun intended.) I am leaving to drive 6hrs into NM for college tomorrow morning at 6am and this morning was supposed to be my final simple maintenance day. Oil change, OPRV re sealing, and timing cover install and checking belt tension.
I did a timing belt, all front seals, oil pan gasket, and rod bearings in March, and left the top belt cover off so I could inspect it in times like today. I had noticed some belt shavings over the months but thought it was a normal break-in type thing. Didn't realize the entire timing belt was shredding off.
Update as I type up the thread... Looks like the belt is being forced towards the block and shredding on the back belt cover. First thing we're checking is maybe I installed the timing tensioner backwards with the flange out.
This pic is me holding a new timing belt next to the one in the car...
Today I got
My Custom Title
My Custom Title
UPDATE: Is there supposed to be some sort of washer behind the timing belt tensioner??? My tensioner is positioned correctly, see picture.
Also. I believe I used a late car roller kit in my 83. Are the later belt tensioners different?? Ex, deeper behind the flange in the rear?
Looks like adding a washer behind the tensioner will fix my problem, but I'll never know.
What's more impressive is that the car is still running strong after driving on this for 5 months, and driving real hard at times.
Today I got
My Custom Title
My Custom Title
Update... We're thinking the rollers and belt are all on correctly but the problem is in the rear belt cover being not fitted properly or something.
The belt should be relatively centered on all of the pulley gears. On my S2, there is a washer behind the crank pulley for the timing belt, which bumps out the pulley and allows the timing belt to align correctly. I'm not sure if the early cars used the washer, but I don't see why they shouldn't, so you might want to search the forums.
Today I got
My Custom Title
My Custom Title
I redid the entire crank seal/oring/pully assembly and I am positive everything is correct on it!
My tensioner has a lot of thread after the nut (see pic) so I'm going to first figure out where on the rear cover it's rubbing, then add a washer behind the tensioner.
Sausagehacker what's up with urs?
My belt is just making sketchy noises... here's the thread I started
I actually just took it too a shop an hour or so ago. I need it reliable this week, ain't nobody got time fo dat!
Today I got
My Custom Title
My Custom Title
The covers seem sturdy but who knows. My dad is currently tearing the front end apart! I think the rear cover is warped or something. Maybe it wasn't seated correctly, who knows. Either way, we're just gonna reinstall with a new belt and NO BELT COVERS, BIAAATCH!
Today I got
My Custom Title
My Custom Title
Update, with lots of pictures.
Pics before we pulled the belt.
You can see the rub point:
New belt under old belt:
The gouge in the rear cover.
ah I feel you guys. I'm also going back to school (5 hour drive) and i'm still finishing my rod bearing replacement and while doing that i found out my new water pump I installed couple weeks ago has a leak.....not sure yet if it's from the gasket or the actual pump. kind of pissed.
