Bumper crooked and off center
I just pulled my front bumper to drill the shocks.
It took some finagling to get it out on the driver side but I got it out and shocks got drilled.
Then when I re-installed it I bolted it back up and pushed it in and only the passenger side pushed in all the way. So I tried to pull it out and try again but only the passenger side will shift now. The driver side is locked up in a partially pushed in state.![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
No matter how hard I push or pull it won't budge. Should I hook my truck up to it to get it back out? I don't want to damage anything on accident.
![](http://i1285.photobucket.com/albums/a581/BrentShanahan/porsche_zps4a85c74c.jpg)
Also when I had the passenger side pushed all the way in I noticed the bumper was off center when looking at it from the front. There is a much bigger gap on the passenger side. That may have just been because the bumper was crooked though.
Any thoughts on fixing these issues?
![](http://i1285.photobucket.com/albums/a581/BrentShanahan/porsche2_zps0aa55255.jpg)
The bigger gap is just because the bumper isn't pushed in all the way on the other side...When I pushed my bumper in I drilled the shocks, then compressed them to an even length, then installed them...you may need a universal (bendy) joint to get at the bolts without screwing up the paint on the valance.
Cheers, and good luck!
Ethan
P.S. You can also use the U-joint to get the bolts out if you're having a problem getting the bumper off.
Ethan
Ya the bumper is bolted on but the shock is jammed. I think I may be able to get at the bolt with one of those bendy socket joints so I'll give that a shot.
Once its off though is there an easy way to actuate the shock back out?
I might try sticking some steel rod through the shock's bolt holes and with some foot bracing, give it a solid pull.
I would remove both shocks and try and get them to compress the same amount before reinstalling them.
I'm not sure why there is a fad with destroying the bumper shocks, but please keep in mind that if you bump the front end now your frame is going to take that impact 100%.
