Torque Specs on plugs?
I was taught early on by a Porsche tech I worked under.
run it in by hand until it is seated.
with help from a ratchet if necessary.
Apply 90 degrees of angle torque.
Done.
I have never seen anyone pull out the little torque wrench for plugs.
Done.
[quote]Originally posted by Tabor Kelly:
<strong>20 ft/lbs??? Craig I wouldn't use that number until I verrified it. That seems aweful heigh (I could be wrong).</strong><hr></blockquote>
True...
My method has worked flawlessly...try it.
perhaps they meant NM and not FT/lb?
True...
I just did the plugs on my 84 n/a and I used the following method:
1. Carefully remove old plugs (duh)
2. Inspect them in order to check for certain types of wear. There is a nice guide to checking plugs in just about any car repair manual if you are not sure.
3. Do a compression test while you are there.
4. Start each plug by hand and then use a socket with extension turned by your fingers until you feel resistance (no ratchet).
5. Now torque the plugs to the proper setting(haynes says 18-22 ft/lbs for my car).
[quote]Originally posted by '86turbo:
<strong>Turbo Manual states 25-30 Nm (18-22 ft lbs). I personally like Renntags intructions follow them and you'll be fine.
Brian Hanlon 86 951</strong><hr></blockquote>
Thx Bri.
Thx Bri.
Second this
Used plugs go with an 60 degree turn (washer already crushed)
Do this for years already
Take Care
Second this
Take Care
I've always torqued my 944 plugs to 19 ft lbs. Some people prefer the finger-tight the 90 degree rotation method, but I usually have my torque wrench out when I'm turning bolts. Too loose, you get blow-by the plugs. Too tight, you run the risk of stripping those fragile aluminum threads in the head. If you don't have a good "hand-feel" for torque, use a torque-wrench and avoid the guesswork.
18-22 ft lbs is the spec in the book. The "range" is to accomodate different materials that are used as sealing/compression rings, and whether or not the plug has been inserted "once" or "a few" times. The compression ring squishes at 18 ft lbs, but subsequent re-tightening may need 2-3 ft lbs more to ensure a good seal. The sealing ring is not designed for repeated insert/removal cycles.
Greg
Greg
[quote]Originally posted by Greg Hammond:
<strong> If you don't have a good "hand-feel" for torque, use a torque-wrench and avoid the guesswork. </strong><hr></blockquote>
Very good point...That is a good safe practice.
I personally have never 'torqued' a spark plug.
I dont know any other race techs who have either.
Some times it is necessary to reinstall and reinstall and reinstall a set of plugs. as for the crush/ sealing ring....I never change them...and have never had a problem. Perhaps I am lucky.
NOTE: Some spark plugs dont even have a crush ring.
