test
![Red face](https://rennlist.com/forums/images/icons/icon11.gif)
Just tring out some stuff... sorry to waste the BW.
Hi, I'm a geek
Dude, I'm serious!
skip@tech-session.com
Click Grapic to Enter
[ 30-05-2001: Message edited by: Skip ]
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Dude, I'm serious!
![](http://www.tech-session.com/Paragon/Fun/cars/cars_images/skipg_944_2.jpg)
The only thing to fear... is ME
- Sleepy
- Dopey
- Sneezy
- Sleezy... doh!
![](https://members.rennlist.com/skipgrehan/paragon_logo.gif)
No prob...
This forum uses something called "UBB Code" [ultimate bulletin board]. You can use the "Instant UBB Code" buttons below the text box to insert the desired effect. [or, you can type them into the text box yourself] You may also use them in combination... say to dispay an image and use it as the clickable Hyperlink. Like this:
Click Here for Discount Porsche Parts and Accessories...
UBB is almost the same as HTML... in that the command lines are similar, and, the begin/end statements are the same... but, instead of <> this uses [] for formating. Also, John has only installed portions of the UBB Code option, which means you won't be able to use the full language of UBB... things like [center], [color], and [font=] will not work here.
Good luck!
Good luck!
I think that was at a SCCA Autocross in the Emerald Downs (horse race-track in Auburn, WA) parking lot.
OBTW, will definitely be down to PIR for the Rose Cup Races June 15-17 (prob only at the track Sunday for main events). Gonna combine it with an anniversary, so I'll have to drag the wench along too
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Originally posted by Skip:
<STRONG>Just tring out some stuff... sorry to waste the BW.
[ 30-05-2001: Message edited by: Skip ]</STRONG>
SG
Thanks! They're Gotti 3-piece 16x7&8 with Kumho Victoracer V700's 225/50 & 245/45.
This is about the lightest 16" wheel available... less than 16# each (rears are actually lighter than the fronts due to the smaller diameter cast center)
I wouldn't recommend these to anyone
They are old (stopped production in 1986) and use old technology... they bend easily and lose the airtight seal quite often.
Here's a link to more info on them...
![](http://www.tech-session.com/Paragon/Info/Info_images/gotti_1_440_2.jpg)
