Early 944 Evaporator Temp Sensor
I am working on making the a/c in my early 944 functional and have identified the evaporator temperatures sensor as a possible source of problems. When I measure the resistance in the sensor I get about 195 ohms. I read elsewhere on this forum that a good sensor should read about 146 ohms. Is this the correct value for a good sensor? Does anyone know what the operating resistance range is for this sensor? Is it safe to bypass it with a jumper to see if it is the cause of my a/c problems, or should I bypass it with an appropriate resistor? Any and all help is greatly appreciated.
Andrew
Andrew
Proprietoristicly Refined
1983, 944, ac, evaporator, porsche, problem, refrigerant, replacement, sensor, switch, symptoms, temp, temperature, turbo
