Evaporator Temp sensor Early 944
Does anyone have the correct resistance readings for this part? I'm trying to figure out why my compressor won't engage. If i jump the wire clutch wire at the amplifier connection it blows cool. I replaced the amplifier with a used part (no idea if it actually works) and it didn't fix the problem. Everything else seems to check out.
Proprietoristicly Refined
I have the early setup on my 924Ss.
Is this the part resistance you need? 146.5 ohms
This is a good spare part and I have not used it. I guess the resistance should be correct.
John
John
I would if I had a spare. This unit has never been opened and I may need it in 10 years for one of my cars. I plan to be buried in my '88
Glad you found your problem.
John
John
Pelican can get it. Double check to make sure my number is correct:
http://www.pelicanparts.com/cgi-bin/...0TEMP%20SENSOR
An aftermarket interchange (VW Audi ??? )temp sensor should also work.
A local AC shop if you are near a large metropolitan area should also have it. ( or maybe a repair shop in the used parts department ??)
GL
John
GL
John
Man, can't believe I missed that! I guess it's because I was searching in the 944 section, and pelican only lists it in the 924 section despite being a 944 part as well.
Yeah sure. How does $15 shipped sound? (USPS flat box is $5) The part is $22 at Pelican, so I'm just basing it on that. You don't happen to have a buzzer relay either do you? Or a parking brake switch?
