86 944 na - Turbo wheels
Assuming that I can put the 16" 86 turbo wheels on my 86 na... is it correct for the factory equipment to have different sidewall heights between the front and back. I understand width is different, but tirerack tells me that factory fronts are 205/55-16 and rears are 225/50-16...
thanks
thanks
Deer Slayer
Take a look at the "Watercooler" web site, they have wheel offset info posted there... http://www.cantonia.com/watercooler.html
I have no idea if it's accurate, they have a disclaimer there so I disclaim it too. But I have no reason to think it isn't accurate.
~cheers~
Thaddeus
~cheers~
Thaddeus
I believe that the sidewall height number is not a hard numbers number, that it varies with the width of the tire. Possibly in a ratio er something, I really dont remember. What I do remember is going to a CART race and walking through the pit area...I looked at the size on a tire and the width was in the 300's, height in the 40's or 50's, but the sidewall was pretty high though. That's where I started to wonder about the sidewall height numbers.
My '89 951 has 245/45-16 in back and 225/50-16 up front, so yep...it's correct (the '88 951S and '89 951 have different wheels/tires than the '86-'88 951).
As far as offsets (to see if wheels fit), check the watercooler with the link that Thaddeus gave.
In a tire size like 225/50R-16, the "225" is the width of the tire in millimeters, the "50" is the % ratio of the sidewall height to tread width. So, your true sidewall heights are:
225 * 0.50 = 112.5mm for the backs
205 * 0.55 = 112.75mm for the fronts
The 0.25mm height difference isn't noticible when looking at the car, but yes - the heights are indeed "different".
Keep in mind, the width number isn't a hard-fast rule in determining true tire width. Some manufacturers/brands of 225 wide tires might be the same as another manufacturer's 215 or 235 wide tire. Go figure.
Greg
Greg
in 1986 several tire/wheel combinations were available.The entry level was 185/70-VR15 front & rear.The wheel offset was 23.3 mm.
Second option was 215/60-VR15 front & rear with wheel offset 23.3mm.The third option was 205/55-VR16, wheel offset 23.3mm front & rear.The fourth option was so called sport pacakge with 215/60-VR15 with wheel offset 23.3mm rear & 10.6mm front.
All wheel were 7 j x 15 or 7 j x 16 expect the sport pakcage has 8 j x 15 rear wheel.
1986 Turbo has 205/55-VR16 front tiers & 225/50-VR16 rear tiers.The wheel size was 7 j x 16 front & 8 j x 16 rear.The offsets were 10.6 front & 23.3mm rear.
Olli
'88 Turbo
Olli
'88 Turbo
Olli, Best info I can find suggests that US cars were only available with 15" wheels with 215/60-15, or 16x7&8 with 205/55-16 & 225/50-16 from the factory. It seems that there are always fewer options here then on cars built for other parts of the world.
I made a new 944WheelsFAQ on my website and shows you how to correctly measure and calculate wheel sizes and offsets: http://members.rennlist.org/951_racerx
